[GRASS-user] Change SQLite DB Column Width?
Greetings,
I am attempting to patch vectors together with v.patch -e (I need the attributes). But I am getting this error:
ERROR: Length of string columns differ
Upon inspecting the columns, I see that at least one vector has a NAME column with a width of 120 characters, while most of them have a width of 80:
db.describe table=TrailSegment_12
column:NAME
description:
type:CHARACTER
len:120
scale:0
precision:0
default:
nullok:yes
select:?
update:?
Is it possible to change the width of the columns? The DB is SQLite.
I tried altering the width using db.execute and this SQL:
ALTER TABLE TrailSegment_12
ALTER COLUMN NAME CHARACTER(128)
But I get the errors:
DBMI-SQLite driver error:
Error in sqlite3_prepare():
near "TrailSegment_Michigan": syntax error
ERROR: Error while executing: 'ALTER TABLE TrailSegment_12'
Seems like there must be a way. I found SQLite has a .width command, but I am not sure how to use it.
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
Hello Jeshua,
to my knowledge, no way to alter a column in sqlite3 :
https://www.sqlite.org/lang_altertable.html
.width only affects the output width of columns within sqlite3 prompt.
I would suggest you to simply add a new column (with the right width),
then copy the content of the previous to the new one and trash the
former.
Hope this helps,
Vincent.
Le jeudi 03 août 2017 à 17:19 -0600, Jeshua Lacock a écrit :
Greetings,
column:NAME
description:
type:CHARACTER
len:120
scale:0
precision:0
default:
nullok:yes
select:?
update:?
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
grass-user mailing list
grass-user@lists.osgeo.org
Hi Vincent,
Thanks for the verifying; I was afraid of that.
:wink:
I see, thank you.
former.
That is a great suggestion, thank you.
Is there a way to copy a column to a new column? It looks like db.copy copies a whole database, not just a column..
Will I have to use SQLite to do it? I’ve never actually used it directly before, so any examples would be greatly appreciated!
Best,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
you can either operate from an sqlite3 session, or use the grass builtin
command db.execute. In your case, it would look like this:
        db.execute sql='update my_table set
        my_new_column=my_former_column'
V.
db.execute sql=‘update my_table set
my_new_column=my_former_column’
In addition, this module should do the job as well:
https://grass.osgeo.org/grass72/manuals/v.db.update.html
On jeudi 3 août 2017 17:19:56 CEST Jeshua Lacock wrote:
Greetings,
column:NAME
description:
type:CHARACTER
len:120
scale:0
precision:0
default:
nullok:yes
select:?
update:?
near “TrailSegment_Michigan”: syntax error
ERROR: Error while executing: ‘ALTER TABLE TrailSegment_12’
As column width is just a hint in SQLite and has no influence on the database structure (you can insert fields that are longer than the declared size), you can just edit the sqlite_master table (which is generaly a dangerous game, and must be done only when you know what you are doing)
With the sqlite3 shell :
PRAGMA writable_schema = 1;
UPDATE SQLITE_MASTER SET SQL = 'CREATE TABLE TrailSegment_12(column_definitions_before_name, NAME CHARACTER(128), column_definitions_after_name) ’ WHERE NAME = ‘TrailSegment_12’;
PRAGMA writable_schema = 0;
so basically get the existing SQL definitions of the table with “SELECT SQL FROM SQLITE_MASTER WHERE NAME = ‘TrailSegment_12’”, edit it to change the column width, and put it in the above UPDATE
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
UPDATE SQLITE_MASTER SET SQL = 'CREATE TABLE TrailSegment_12(column_definitions_before_name, NAME CHARACTER(128), column_definitions_after_name) ' WHERE NAME = 'TrailSegment_12';
so basically get the existing SQL definitions of the table with "SELECT SQL FROM SQLITE_MASTER WHERE NAME = 'TrailSegment_12'", edit it to change the column width, and put it in the above UPDAT
Hi Even,
Thanks for your help.
If I could figure out exactly what you mean, I think this might be the most elegant solution.
But when I run:
sqlite> SELECT sql FROM sqlite_master WHERE type = 'TrailSegment_12’;
sqlite>
It doesn’t display anything and just returns to the sqlite prompt.
Best,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
On vendredi 4 août 2017 16:22:57 CEST Jeshua Lacock wrote:
On Aug 4, 2017, at 2:03 AM, Even Rouault even.rouault@spatialys.com
are doing)
column_definitions_after_name) ’ WHERE NAME = ‘TrailSegment_12’; PRAGMA
SQL FROM SQLITE_MASTER WHERE NAME = ‘TrailSegment_12’", edit it to change
Hi Even,
elegant solution.
But when I run:
The condition is name = ‘TrailSegment_12’ not type =
sqlite>
Best,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
On Aug 5, 2017, at 10:11 AM, Even Rouault <even.rouault@spatialys.com> wrote:
Doh! Thanks - I had copied in your SQL but when it didn’t work I resorted to finding more examples on the web.
The reason why your suggested SQL wasn’t working was because I wasn’t setting the database connection with :
.open /Volumes/bigy/National/transportation/PERMANENT/sqlite/sqlite.db
I was able to reconfigure the schema as you suggested, and when I re-ran the SELECT SQL command, it showed the new size:
sqlite> SELECT SQL FROM SQLITE_MASTER WHERE NAME = 'TrailSegment_Wyoming’;
But v.patch -e still wouldn’t work. I looked at the table in the GUI and it still showed the old width of the column:
So as far as I can tell this solution won’t work, which is a bummer. I ended up getting around the issue by copying a target table, dropping all rows then inserting rows from the mismatched table (essentially as Vincent suggested).
I think it would be REALLY nice if we could supply a schema when importing with v.in.ogr. Apparently it allows you to specify the columns (but not specify their data type and width?). For instance I wish something like this worked:
v.in.ogr columns=“GNIS_ID varchar(80), NAME varchar(128), etc.”
That way, if as long as I used the same schema for different imports, they would all be combinable without any issue.
Best,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
