Most of the modules I run in my hydrologic analysis use feet without
complaint. However, to apply Laurent's Ixzi the input units need to be
metric. I'd like advice and suggestions on how to accommodate this need with
the existing location, mapsets, and vector/raster maps. Alternatively, if a
new location needs to be created how I would specify its parameters.
The location's projection is static (AFAIK). If you create a new
projection, you can project data into the new location with units of
meters.
EPSG 2838 is oregon north nad83/harn with horizontal units of meters.
I did not find that in my searches of EPSG codes. That'll do the job,
thanks.
Following your pointer I see why I missed recognizing that EPSG 2838 was
what I wanted: the projection formats do not include the units of measure.
When I looked at all Oregon North projections I saw that the name for EPSG
2913 explicitly includes (ft). Ergo, if the units are not mentioned they
must be SI (meters).
