Hi all!
I use ‘i.maxlik’ for image classification. The output obtained shows water in green, built-up area in blue, vegetation in red and so on. It would be appropriate if water appears blue and I had the ability to customize other colors. Where and how do I specify these details in my sequence of operations which is as follows:
Vector layer containing training sites imported from QGIS
Conversion of vector to raster
Generation of signature sites using i.gensig
Classification using i.maxlik
I tried adding a column(inputs ‘varchar’) “color” with RRR:GGG:BBB values to my vector generated in first step but the colors didn’t come according to that in the final output.
Thanks and regards,
Chethan S.
