Dear all,
I just imported a shapefile on GRASS, and I need to convert several fields from CHAR to numeric (double precision) - at my own risk, of course.
Can I do it on grass, or I need to redo the thinks on arcgis ?!
bests
milton
brazil=toronto
Dear all,
bests
milton
brazil=toronto
On 02/07/09 18:52, Milton Cezar Ribeiro wrote:
Dear all,
Depends on your database backend. In PostgreSQL (and perhaps SQLite), you could do something like this:
echo "alter table XYZ alter column ABC type numeric" | db.execute
I don't think anything like this would be possible in dbf...
You could also try a combination of v.db.addcol + v.db.update to create new numeric columns and set the value of these columns to the value of the varchar column.
Moritz
Hi Moritz,
As I am using dbf, with v.db.addcol + v.db.update it is running find.
Thanks!
milton
2009/7/2 Moritz Lennert <mlennert@club.worldonline.be>
Dear all,
Can I do it on grass, or I need to redo the thinks on arcgis ?!Depends on your database backend. In PostgreSQL (and perhaps SQLite), you could do something like this:
echo “alter table XYZ alter column ABC type numeric” | db.execute
I don’t think anything like this would be possible in dbf…
Moritz
