Greetings
I’m making some addaptions in menudata.xml in order to have a few functions available more rapidly (for me). I wanted to have a menu-item (I know how to add it) that runs directly without opening any panel. This would mean that all parameterization would be in the xml. Is this possible?
Greetings
Thank you
Franz
2010/6/9 Franz Schiller <franzschiller1975@gmail.com>:
Greetings
I'm making some addaptions in menudata.xml in order to have a few functions
yes, it's possible in 6.5+. In 6.4 it will be probably not working.
<menuitem>
<label>Info elevation map</label>
<help>Show menudata of elevation raster map</help>
<handler>OnMenuCmd</handler>
<command>r.info map=elevation</command>
</menuitem>
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hi Martin
the OnMenuCmd it doesn’t exist so I used self.OnMenuCMD and the r.info frame module appeared with inserted parameters but it was not possible to avoid the appearence of frames module. Has anyone has a suggestion regarding this?
Thanks
Franz
On Fri, Jun 18, 2010 at 1:35 PM, Martin Landa <landa.martin@gmail.com> wrote:
Greetings
yes, it’s possible in 6.5+. In 6.4 it will be probably not working.
Info elevation map
OnMenuCmd
[r.info](http://r.info) map=elevation
Martin
Hi
Martin, it’s not possible in GRASS6.4.0RC6. It still opens the module-panel and parameterizes it. has anyone ever tried to have a module that runs, from the menu, without opening module-panel?
Thanks
Best regards,
Franz
Greetings
Info elevation map
OnMenuCmd
Martin
