Is there a way to increase output resolution of ps.map module? Default
is 72 dpi.
Maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI |http://www.geocities.com/esambale/philbiodivmap/philbirds.html |
I just found it out through the archives. Its hardcoded in the code.
One way to increase reolution is to increase page size.
On 7/31/06, maning sambale <emmanuel.sambale@gmail.com> wrote:
is 72 dpi.
Maning
> is 72 dpi.
Not any more; the downsampling was removed on 2006/02/14. Recent
versions always output raster maps at the resolution of the current
region.
OK thank you for the info.
maning
> > is 72 dpi.
region.
