Dear friends,
I have a shape file, with some polygons. (I have imported it as vector layer.)
I have a point, expressed as X,Y coordinates (Easting,Northing).
I want to know if the point is inside any of the polygons in the shape file.
Is there a command I can use?
I would rather use command line, because I have many points, really. I would
like to find a way to do it from the command line, so that I can write a
routine to extract each point and check if it is inside the polygons.
I can rephrase the question, if it is not clear.
I am not very experienced with Grass but would like to substitute ArcGIS, that
we are using now.
Best regards
Corrado Topi
Global Climate Change & Biodiversity Indicators
Area 18,Department of Biology
University of York, York, YO10 5YW, UK
Phone: + 44 (0) 1904 328645, E-mail: ct529@york.ac.uk
Corrado,
You can do this with v.select:
v.select ainput=input_points binput=input_polygon out=output_points
John
On Mar 3, 2008, at 8:02 AM, Corrado wrote:
Dear friends,
we are using now.
Best regards
Corrado Topi
grass-user mailing list
grass-user@lists.osgeo.org
