[GRASS-user] CHELSA climate data set
Hi Markus,
:stuck_out_tongue:
Yes, it seems I did… nice way of discovering underlying misconceptions :-/ Don’t know where it came from though
Thanks again
Vero
El 3 may. 2017 3:06 p.m., “Markus Metz” <markus.metz.giswork@gmail.com> escribió:
Hi Vero
On Wed, May 3, 2017 at 1:57 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
In the end, I found that the only way to get chelsa maps with the same resolution and extent than the MODIS 1km maps, was to import the whole chelsa map and subset with r.mapcalc since it uses the region settings.
Maybe you assumed that r.in.gdal -r is also doing resampling. The -r flag only cuts the input to cover the current region. For resampling you can use one of the r.resamp.* modules.
