Hi Rich
On 8/14/20 5:41 PM, Rich Shepard wrote:
I'm starting a large project and want all data (geometric and attributes) to
be stored in a new postgres database I just created: washington_state. Both
postgresql-12.2 and postgis-3.0.1 are installed.
To be clear from the start, GRASS *always* stores geometry in its own database structure. The attributes can be stored in a number of ways: back in GRASS 6.x days, attrib tables were kept in the old dbf format. Since 7.x, sqlite is the default file format for attrib tables. You can alternatively choose to save your attribute tables to PostgreSQL (db.connect...). But again, don't confuse - this is NOT PostGIS, and GRASS does not need/use PostGIS for geometry. GRASS geometry is always independent of any external geospatial format.
All my previous work has used the default GRASS database so I've read the
manual page, PostgreSQL DATABASE DRIVER, and I'm still unsure how to
proceed. I'm the only postgres user so I access all my databases without
entering a username or password.
When I start a grass session, create a new location, and mapset then want to
import .shp or .gdb files how do I specify using the postgres/postgis
database I just created? When do I use PostGIS with shp2pgsql?
It's the other way around: When you export GRASS map layers, you can, as you know, choose to save out to several formats: shp, Geopackage (the current default) or to PostGIS. PostGIS is the best choice when you need multiuser access to the geospatial data. But you point out that you're the only user, so why would you need the overhead of PostGIS?
When importing a shapefile or other vector data, only the attrib tables get saved to some database: sqlite by default, or PostgrSQL if you have configured for that backend. But the geometry is still kept in the GRASS vector format.
Since I've used the db.* modules before I'm familiar with them. What I need
to learn is how to expand my grass experiences to using post* as the
databases rather than the defaults.
To repeat, you can set the default for saving attribute tables to PostgreSQL, but do not try to save a GRASS layer to PostGIS in the same database! That will definitely lead to trouble. If you want/need a PostGIS instance for some reason independent of GRASS, then keep it totally separated from GRASS. i.e. at least in a separate schema or even separate database.
The main reasons for choosing PostgreSQL as your database backend would be
1. to allow fancy SQL queries on the database tables
2. huge, complex data tables or triggers
3. multiuser access to the attribute tables
But keep in mind that the default sqlite database is quite powerful, and you would have to look very deeply to find a PostgreSQL feature that is missing in sqlite.
Best regards, Micha
A pointer to other docs would be great.
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
