Surely a stupid question, but I can’t find a way to clip a raster on the base of the region settings and/or the base of a vector. I can MASK, I can reclass, but I can’t clip!
Furthermore, is it possible to rotate a raster without the use of a 1st polynomial rectification through GCPs?
if you already have a raster that fits your region then simply create a
MASK and just create a new raster with r.mapcalc.
r.mapcalc clipped_rast=rast
(r.mapcalc works only on the MASK so you can quickly clip any raster
like that).
On Fri, 2008-01-25 at 00:15 +0100, G. Allegri wrote:
Surely a stupid question, but I can't find a way to clip a raster on
MASK, I can reclass, but I can't clip!
I don’t have a raster that fits my region. I should create a vector with v.in.region, rasterize it and use it as a MASK… well, I hoped there was something more linear. The same could be used to clip on the base of a polygon.
The unsolved problem is rotation (and shift): making affine tranformations using just a x-shift and y-shift parameter, and a rotation angle having set a point as origin (or just around the “center” of the raster).
like that).
Giovanni
grass-user mailing list grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Although I don't know how (!) I read in a post about i.rectify... Why
don't you dig-up the man page...
Nikos.
On Fri, 2008-01-25 at 00:53 +0100, G. Allegri wrote:
I don't have a raster that fits my region. I should create a vector
with v.in.region, rasterize it and use it as a MASK... well, I hoped
base of a polygon.
"center" of the raster).
create a
raster
like that).
raster on
I can
use of a
> Giovanni
Nikos Alexandris
Nikos Alexandris
Nikos, I ask because I’ve read almost all the pages of the manual. I use i.rectify: it is the tool to rectify rasters on the base of GCPs. This is not the case.
Although I don’t know how (!) I read in a post about i.rectify… Why
don’t you dig-up the man page…
Nikos.
base of a polygon.
create a
raster
like that).
raster on
I can
use of a
Giovanni
Nikos Alexandris
Nikos Alexandris
for rotation by angle you could do more complicated stuff in Matlab.
In GRASS i.rectify may be an option.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
Surely a stupid question, but I can't find a way to clip a raster on the
r.resample will resample a map according to the current region
settings.
To clip to a vector map, convert the vector area(s) to a raster then
use it as a mask.
No.
You can translate and/or scale a map by changing its boundaries with
r.region, but the only tool to rotate or skew a map is i.rectify
(there isn't an r.rectify).
