on 7/6/08 12:00 PM, "Markus Neteler" <neteler@osgeo.org> wrote:
On Sat, Jul 5, 2008 at 7:28 PM, Dwight Needels <needels@translucida.com>
wrote:Hi all,
What is the quickest way to clip a vector to the current region, while
ending up with the attribute table retaining all original field names and
data values?Dwight,
see v.in.region and v.overlay/v.select.
Thanks, Markus (v.select is exactly what I was looking for).
I had been trying to use v.overlay to clip a line vector map (of roads), but
it added an "a_" prefix to each of the field names in the attribute table. I
also seemed to have to add a centroid to the vector created by g.in.region
to get v.overlay to work. Finally, v.overlay resulted in 5,451 lines
compared to 5,444 from v.select. The extra lines were copies of 4 lines that
all happen to intersect the binput map boundary.
-Dwight
