[GRASS-user] Cliping/cropiing DTM with boundary of City
Is it possible to clip (crop) a rectangular DTM raster with irregular
boundary of city (as vector map), so that I can view only city area
filled with DTM. nothing beyond that.
If this can be done, then which command or option will do this?
Please help me.
H.S.Rai
Here are two suggestions:
You can use the ‘-cutline’ option to gdalwarp to clip a raster to a polygon. Have a look at this blogpost for details: http://linfiniti.com/2009/09/clipping-rasters-with-gdal-using-polygons/
Within GRASS, you can rasterize the clip polygon calling in “MASK”:
v.to.rast in=city out=MASK use-val value=1
THen run:
r.mapcalc clipped_DTM=original_DTM
Since r.mapcalc honors the MASK, the new raster should be clipped to the city polygon.
Thanks very much, I worked.
It has one typo, which made my 1st trial unsuccessful, but quickly I
was was able to find that. So, I am reporting here for the benefit of
other user.
"use-val" in 1st command needed to be replaced by "use=val".
Thanks for quick response.
H.S.Rai
