Is there an easy way to clip a LiDAR data file?
I have a 2GB raw dataset which I imported with v.in.ascii without
topology or creating database because that caused memory to get full.
I was going to just run the v.lidar.edgedetection for the whole dataset,
but that seems to take forever..
So I thought I could clip down the vector to a subsample using
v.in.region and then v.overlay, but this produces an error because of no
topology, fair enough! So maybe I can build the topology with
v.build...again memory runs out.
Any ideas? Thanks, Jack
maybe v.select?
Carlos
grass-user mailing list
grass-user@lists.osgeo.org
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
carlos dot grohmann at gmail dot com
http://www.igc.usp.br/pessoais/guano/
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can’t stop the signal.
Hi Jack. Did you try the "-r" switch?
Something like "g.region" or "d.zoom" to some sub-region, then
"v.in.ascii -r in=... out=..." ?
Kind regards, Nikos
