Is the best way to clip data to use the v.overlay command with the “and” operator?
it works great, but seems quite slow on larger datasets. Additionally as an example, if i have topographic contour lines, and i want to clip them to a polygon, and only want the topo line attributes (elevation) outputted, is there a way to do this? Is there another way to clip line data to within a polygon that might be a bit faster?
Is the best way to clip data to use the v.overlay command with the "and"
operator?
run v.select, then v.overlay. That way the intensive v.overlay operation only
happens for relevant vector features. Then it will speed up hugely.
I wonder if v.select functionality could be built into v.overlay as a
preprocessing step?
Hamish
____________________________________________________________________________________
Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games. http://sims.yahoo.com/
> "and" operator?
> be a bit faster?
Hamish:
operation only happens for relevant vector features. Then it will
speed up hugely.
preprocessing step?
(see Radim's doc/vector/TODO in the source code; maybe splitting long
boundaries helps too?)
Sorry if my answer is a bit out of the scope of Grass :
from time to time I use OpenJump GIS. For this type of task (don't ask
me why) it's incredibly faster. Maybe any of you could explain this
difference ?
VB
Le vendredi 17 août 2007 à 17:21 +1200, Hamish a écrit :
> > "and" operator?
> > be a bit faster?
Hamish:
> speed up hugely.
> preprocessing step?
