I thought I created a clipped DEM by rasterising an irregular vector
boundary and then using a mask to create the clipped DEM from a
rectangular DEM.
For example:
# convert vector border to raster
v.to.rast input="border" output="border" use="cat" type="area" layer=1
value=1 rows=4096 |
# set the mask to the raster border
r.mask border
# create the clipped DEM
r.mapcalc
dem_clipped=dem_full
# remove the mask
r.mask -r
But it turns out I was wrong, the 'clipped' raster just contains NULL
values outside of the border raster. What did I do wrong? Is there a
better way to clip a raster to a vector boundary?
Thanks
Hanlie
rectangular DEM.
For example:
#first, check and set your region of interest
g.region vect=border -pa
value=1 rows=4096 |
r.mask border
r.mapcalc
# remove the mask
r.mask -r
So, always check the region ;-). I think this is the best (and only?) way to
clip.
Regards, Nikos
Hanlie Pretorius pisze:
rectangular DEM.
For example:
value=1 rows=4096 |
r.mask border
r.mapcalc
# remove the mask
r.mask -r
Thanks
Hanlie
grass-user mailing list
grass-user@lists.osgeo.org
nothing, everything is OK, if you want change raster size (i.e remove areas outside vector) just do
value=1 rows=4096 etc..
but you will still will have null values outside the the vector, if it has irregular shape
J.
2010/8/10, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
rectangular DEM.
For example:
Tried this with the same result, as Jarek points out in the second
reply. So, I assume it's impossible to have a raster with an irregular
boundary in GRASS?
value=1 rows=4096 |
r.mask border
r.mapcalc
# remove the mask
r.mask -r
clip.
Regards, Nikos
rectangular DEM.
For example:
boundary in GRASS?
value=1 rows=4096 |
r.mask border
r.mapcalc
# remove the mask
r.mask -r
clip.
Regards, Nikos
raster is a matrix of values so it is always rectangular. Null is not a value, NULL is lack of value. Irregular raster is a rectangural raster with null (transparent) cells outside the border
J.
Nikos A:
boundary in GRASS?
I don't think so. GRASS raster engine is eXtremely powerfull. You can even
sketch circles if you'd like using r.mapcalc
>> value=1 rows=4096 |
>> r.mask border
#replace the above and use r.mapcalc instead:
r.mapcalc MASK=border
>> r.mapcalc
>> # remove the mask
>> r.mask -r
Nikos
2010/8/10 Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
>> r.mask border
why?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hanlie P:
reply.
Sort of off-topic (but important to me): for some reason Jarek's e-mails got
filtered and dropped in another folder that is why I replied (again) about
g.region.
Nikos
>> >> r.mask border
why?
Right. I should first ask what the values compose the raster that is to become
a MASK. In the past I had problems with r.mask (if it is important I will
trace down the thread) I think when using it on floating point maps (values
like 0.2, 0.3, 0.4, etc.) and they got rounded (or truncated?) to 0 or
something similar.
But, in this case the "value=1" is assigned so it should make no difference. I
was too quick. Sorry.
Nikos
