[GRASS-user] Clipping Very Large Vector Map
   I have a map of streams and rivers that is about 474M for the coor file
and 65M for the topo file; very large. The area of interest is very much
smaller and I tried using v.overlay with the 'and' (intersect) operator to
clip the huge line map with the small area map. After about 1/2-hour of
processing the system shut down because the CPU overheated (at it's only 20C
here today).
   Are there other modules, or ways of using v.overlay, that will allow me to
trim off smaller chunks of the line file?
TIA,
Rich
maybe gdalwarp can do it? it has a clipping option where you give coordinates of a rectangle.
best
Carlos
On Mon, Oct 8, 2012 at 8:28 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
smaller and I tried using v.overlay with the ‘and’ (intersect) operator to
processing the system shut down because the CPU overheated (at it’s only 20C
here today).
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
Can’t stop the signal.
Carlos,
   The clip box is not quite rectangular. In any case, I think it is the huge
size of the line map on a system with "only" 4G of memory that might be the
problem.
   Looking at v.select suggests that it might work, but I've no way of
knowing if it is any more efficient than v.overlay, and I don't want to
re-boot my server/workstation again. :slight_smile:
Rich
to trim off smaller chunks of the line file?
   If I create a new map of a box that is slightly smaller in are than the
large stream/river map, and use the 'not' operator with v.overlay, will this
be a quicker way of trimming off the lines external to the new box?
   If so, I can keep creating new boxes, each smaller than the last, and clip
the line map in smaller bites.
Rich
   area
try using v.select.
here today).
TIA,
Rich
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Enviado desde mi teléfono Android con K-9 Mail. Disculpa mi brevedad
On Tue, 9 Oct 2012, Juan Carlos Torrrs wrote:
try using v.select.
Juan,
   That was one of my thoughts, and it did the job when I properly specified
the a and b maps.
   Thanks for the suggestion.
Rich
