[GRASS-user] Coastline extraction
Hi everybody,
I'm using an SRTM .tif file and a vector file (from vmap0 dataset) to clearly define a region.
On the srtm i filled the voids with r.fillnulls, but on the coast the data are no clear and coastlines are not real at all. The sea depth as well is completely "crazy", and I really don't need it!
Since i have got the vector file of the coastline, is there any way to tell grass to execute the command r.fillnulls just until the coastline?
I tried something converting at first the vector file of the coastline into a raster, and then i used the mask command, but I am not able to get the results that i need.
Many thanks!
