Is there a module (or an easy solution) that will generate line features from along-terrain COGO data and a DEM?
m.cogo will generate [X,Y] values from COGO data, but it assumes that the COGO distance measurements have been projected onto a horizontal surface. The only work around I can think of requires computing slope data (from a DEM for instance) to get at an average cosine of the slope underlying each COGO line segment, then correct the COGO distance to get its projected counterpart. For instance, an along-terrain distance on a 45 degree slope of 100.0 meters should translate to a distance of 70.7 meters on a projected plane. This correction can be tedious if manually computed by hand (especially since multiple iterations may be needed to compute the average slope along a line segment). Any ideas?
r.profile, r.transect might help
r.los output map contains vertical angle to target
r.cost?
Maybe v.distance is 3D aware? (I'm not sure). r.distance? (long shot)
