I need to create a histogram equalized color table for a set of rasters. I can use r.colors for each raster individually but then the color tables are not comparable across the maps. Any suggestions on how to create a color table across multiple rasters?
Jitu
Hi list,
does anyone know if there is a way to compute the upslope drainage contributing areas along a stream?
thanks for your help!
Francesco
Hello Francesco,
you could use something like the AddOn r.stream.basin (http://grass.osgeo.org/wiki/R.stream.*)
to delineate the basins. Every basin gets a unique number. Afterwards you can just query how
many cells do have a certain number.
best regards!
Am 13.10.2011 um 08:20 schrieb Francesco Mirabella:
Hi list,
Francesco
grass-user mailing list
grass-user@lists.osgeo.org
It depends on what the OP was looking for - it sounds to me that he is looking for a kind of “dynamic” approach, where one can determine the upslope drainage area for an arbitrary location. Unfortunately, I don’t have a solution, but would be quite interested in the answer.
Rainer
On Thu, Oct 13, 2011 at 8:36 AM, Johannes Radinger <jradinger@gmx.at> wrote:
Hello Francesco,
best regards!
Hi list,
Francesco
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
Hello,
and thanks for your fast replies,
yes, the final result which I'd like to get is a river profile along which the values of the upslope contributing areas can be plotted on a separate y axis.
In order to get this I suppose I should be able to "cat river_long_profile_ascii | r.profile a_raster_map_containing_the upslope_areas" which can provide values in square meters or square km or whatever.
Do you know if such a raster map can be obtained from a dem?
Francesco
Rainer M Krug wrote:
It depends on what the OP was looking for - it sounds to me that he is looking for a kind of "dynamic" approach, where one can determine the upslope drainage area for an arbitrary location. Unfortunately, I don't have a solution, but would be quite interested in the answer.
Rainer
On Thu, Oct 13, 2011 at 8:36 AM, Johannes Radinger <jradinger@gmx.at <mailto:jradinger@gmx.at>> wrote:
Hello Francesco,
best regards!
Am 13.10.2011 <tel:13.10.2011> um 08:20 schrieb Francesco Mirabella:
> Hi list,
> Francesco
> grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
South Africa
email: Rainer@krugs.de <mailto:Rainer@krugs.de>
Skype: RMkrug
On Thu, Oct 13, 2011 at 9:04 AM, Francesco Mirabella <mirabell@unipg.it> wrote:
Hello,
yes, the final result which I’d like to get is a river profile along which the values of the upslope contributing areas can be plotted on a separate y axis.
In order to get this I suppose I should be able to “cat river_long_profile_ascii | r.profile a_raster_map_containing_the upslope_areas” which can provide values in square meters or square km or whatever.
Possibly r.flow could help here - in the manual:
There are three possible output maps which can be produced in any combination simultaneously: a vector map flout of flowlines, a raster map lgout of flowpath lengths, and a raster map dsout of flowline densities (which are equal upslope contributed areas per unit width, when multiplied by resolution).
If you need it more accurate, maybe use r.drain for each cell and add the flowpaths accordingly.
Rainer
Francesco
Rainer
On Thu, Oct 13, 2011 at 8:36 AM, Johannes Radinger <jradinger@gmx.at mailto:[jradinger@gmx.at](mailto:jradinger@gmx.at)> wrote:
Hello Francesco,
best regards!
Am 13.10.2011 tel:13.10.2011 um 08:20 schrieb Francesco Mirabella:
Hi list,
Francesco
grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
South Africa
email: Rainer@krugs.de mailto:[Rainer@krugs.de](mailto:Rainer@krugs.de)
Skype: RMkrug
South Africa
Skype: RMkrug
wrote:
Hello,
axis.
whatever.
by resolution).
Another possibility to get total upslope contributing area for each
cell is the flow accumulation output of r.watershed and r.terraflow.
Upslope contributing areas for arbitrary points can be determined with
r.stream.basins, or one point after another with r.water.outlet. These
modules use drainage direction produced by r.watershed as input.
HTH,
Markus M
Rainer
Hello Francesco,
best regards!
> Hi list,
> Francesco
South Africa
Skype: RMkrug
South Africa
Skype: RMkrug
Many thnaks to all,
I 'll try and see what I get
cheers
Francesco
wrote:
Hello,
axis.
whatever.
by resolution).
HTH,
Markus M
Rainer
Hello Francesco,
best regards!
> Hi list,
> Francesco
South Africa
Skype: RMkrug
South Africa
Skype: RMkrug
