Hi there.
I’m trying to do dome tricks with r.colors.stddev and was wondering if there is a way to know which RGB value will be assigned to a raster value? More precisely, I want to use the r.colors.stddev scheme in a moving-window, so that the central pixel is colored using r.colors.stddev but using only the values of its surrounding pixels.
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
Can’t stop the signal.
José Guerrero published a Python script to produce a raster (*. Asc) with
the sum of neighboring pixels.
Script de python para producir un ráster (*.asc) con la suma de los píxeles
vecinos
<http://joseguerreroa.wordpress.com/2012/08/03/script-de-python-para-producir-un-raster-asc-con-la-suma-de-los-pixeles-vecinos/>
View this message in context: http://osgeo-org.1560.n6.nabble.com/colortable-RGB-value-for-a-pixel-based-on-its-value-tp5009955p5010020.html
Carlos Grohmann wrote:
I'm trying to do dome tricks with r.colors.stddev and was wondering if
Use r.neighbors and r.mapcalc, e.g.:
tmpmap=colors_stddev.tmp.$$
r.neighbors "input=$inmap" "output=$tmpmap.mean" method=average
r.neighbors "input=$inmap" "output=$tmpmap.sdev" method=stddev
r.mapcalc "$outmap = ($inmap - $tmpmap.mean) / $tmpmap.sdev"
r.colors "$outmap" rules=- <<EOF
0% blue
-2 blue
0 white
2 red
100% red
EOF
g.remove "rast=$tmpmap.mean,$tmpmap.sdev"
