Hi!
I have a number of ascii files downloaded from ASTR fire project from
the ESA Ionia showing monthly fire incidences from 1996-2006. I
intend to combine all these files, remove unwanted columns and get the
records from my current region/study area only. All records combined
is 929,155 records! My guess is I need to use the cat, cut, awk
commands.
Challenge: the files have different record formating
file 1 is like this (take note of the space as the delimiter):
Date Time Lat Lon NDVI Station
020201 032428.163 -38.379 -66.334 -.-- ESR
020201 032428.163 -38.375 -66.323 -.-- ESR
020201 032428.312 -38.378 -66.359 -.-- ESR
020201 032428.312 -38.374 -66.348 -.-- ESR
020201 032428.312 -38.371 -66.337 -.-- ESR
file 2 looks like this:
Date Orbit Time Lat Lon
20030101 4384 81704.016 19.364 -155.103
20030101 4384 81704.164 19.373 -155.105
20030101 4384 81704.164 19.375 -155.096
20030101 4385 100833.648 56.638 161.281
20030101 4386 130756.352 -20.340 134.099
I only need the columns for date, time, lat, lon
Here's what I did:
#combine all file (monthly)
cat 9904ESA01.FIRE 9905ESA01.FIRE 9906ESA01.FIRE 9907ESA01.FIRE
9908ESA01.FIRE ... > test
# cut only desired columns (1_4) delimeiter is spac ' '
cut -d' ' -f1 test > 1
cut -d' ' -f2 test > 2
cut -d' ' -f3 test > 3
cut -d' ' -f4 test > 4
# combine all columns
paste 1 2 3 4 > test5
example output:
021231 223941.761 11.035 -5.016 -.-- ESR
021231 224005.303 12.226 -6.243 -.-- ESR
20030101 4380 25934.057 -37.022 -69.589
20030101 4382 45951.090 33.005 -110.772
The problem is for the file example 1, lat and lon columns contain
spaces other than the delimiter example " -38.00" while another is
"120.00" In the file2 example, more spaces are there. I think I need
to process different file formats separately but how do I solve the
problem for spaces in the lat/lon columns?
One last question how do I get the records for my current region only?
north: 20:00:01.49976N
south: 5:00:01.499767N
west: 115:00:01.5012E
east: 130:00:01.501193E
I'm starting to understand awk (reading the gawk manual right now) but
may take a while to get do something magical.
Thanks!
Maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI |http://www.geocities.com/esambale/philbiodivmap/philbirds.html |
