[GRASS-user] command echo?
Hello,
I try to test the different command in the tutorial Grass Book but I have a problem with the "echo" command.
I work on the geometry operation and for the exercice about the split/join segment extraction, I don't know how to use "echo" and his values. I'm working with the Grass 6.4 SVN with Msys.
Thank you to guide me on a way.
Yvan
Hello,
echo is just providing a text output on the screen.
hence
echo "process finished"
should give you:
"process finished"
on the CLI.
I attached a screenshot of a echo command inside a loop including the output.
Perhaps this helps.
regards, Martin
On Montag, 15. Februar 2010 15:01:13 Yvan Paillé wrote:
Hello,
Yvan
grass-user mailing list
grass-user@lists.osgeo.org
Dr. Martin Wegmann
University of Wuerzburg
Institute of Geography
Department of Remote Sensing
Remote Sensing and Ecosystem Research
Am Hubland
97074 Wuerzburg, Germany
German Aerospace Center (DLR)
German Remote Sensing Data Center (DFD)
Phone: +49-(0)931-31-83446
Fax: +49-(0)931-888-4961
Email: martin.wegmann@uni-wuerzburg.de
url: http://www.remote-sensing.uni-wuerzburg.de
url: http://www.dlr.de/caf
(attachments)
