[GRASS-user] Command of the day: merge vector lines in a map
Hello list,
I had a map of a city whose streets were split at each intersection.
This time I needed to make it so that each street be one line.
Not knowing a direct tool to do the job, I came up with the following
command I wanted to share with you.The command creates a script that
calls v.edit to merge the lines based on the street name.
Without further ado, here is the beast:
echo '#\!/bin/bash' > tmp.sh && v.db.select -c map=str columns=a_STNAME
| sort | uniq | sed s,'\(.*\)','v.edit map=str tool=merge
"'where=a_STNAME="'\1'"'"', >> tmp.sh
This generates tmp.sh, which does the job. There probably is a better
way to do it, but this is what did the job for me.
I use tcsh so it might not work with bash.
Happy GRASSing,
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
