[GRASS-user] command works inside GRASS but not with python script outside GRASS
Group,
The following command works using GRASS command session:
v.extract input=const output=const_clean type=area where=“(value=255) and (area_sqf>1000)”
Extracting features…
Building topology for vector map const_cl@PERMANENT
Registering primitives…
7091 primitives registered
54239 vertices registered
Building areas…
2484 areas built
1143 isles built
Attaching islands…
Attaching centroids…
Number of nodes: 5334
Number of primitives: 7091
Number of points: 0
Number of lines: 0
Number of boundaries: 6675
Number of centroids: 416
Number of areas: 2484
Number of isles: 1143
Writing attributes…
But does not work in grass/python script:
grass.run_command(‘v.extract’, input=‘const’, output=‘const_clean’, type=‘area’,where=‘“(value=255) and (area_sqf>1000)”’ )
100%
Building topology for vector map const_clean@PERMANENT
0 primitives registered
0 vertices registered
Building areas…
100%
0 areas built
0 isles built
Attaching islands…
Number of nodes: 0
Number of primitives: 0
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
The GRASS script contains the following imports
#!/usr/bin/env python
import os
import sys
import subprocess
import shutil
import binascii
import tempfile
import shutil
import grass.script as grass
import grass.script.setup as gsetup
Your help is appreciated.
Alassane
2016-07-03 3:02 GMT+02:00 alassane toure <atourej@gmail.com>:
grass.run_command('v.extract', input='const', output='const_clean',
type='area',where='"(value=255) and (area_sqf>1000)"' )
why
'(value=255) and (area_sqf>1000)'
or
would be enough. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Thanks Martin. Your suggestion worked!
Alassane
On Jul 3, 2016 1:51 AM, “Martin Landa” <landa.martin@gmail.com> wrote:
why
‘(value=255) and (area_sqf>1000)’
or
Martin Landa
