When the mouse/trackball pointer is over a checkbox and similar controls
the shape changes from an arrow to a small, open box with short arrows from
the upper left and lower right corners. This blocks viewing of the checkbox
or spinner control. Is there a reason why the cursor changes?
Rich
On Thu, Sep 15, 2016 at 5:13 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
I found out that it's the wx.aui docking widget, which causes the
change in cursor for all the widgets. I am not sure what to do about
it, it would be good to test it with wxPython Phoenix (the new version
of wxPython).
Anna
Rich
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, 15 Sep 2016, Anna Petrá¨ová wrote:
I found out that it's the wx.aui docking widget, which causes the change
in cursor for all the widgets. I am not sure what to do about it, it would
be good to test it with wxPython Phoenix (the new version of wxPython).
Anna,
I don't have time now to install Phoenix and try it with GRASS. If no one
else does the testing I'll do so as soon as I can.
Rich
On Thu, Sep 15, 2016 at 10:26 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Anna,
It's on my TODO list as well, but I am not sure when I will get to it,
so it would be great if you can test it.
Thank you
Rich
