[GRASS-user] common legend for the set of maps
Make sure that your are creating an FP map with float values rather than a cell map with integer values.
Second, your ranges overlap. They need to be non-overlapping to be meaningful in a legend. For example, a value of 0.7 could occur in all 3 of your ranges.
Michael
On Aug 21, 2008, at 4:53 AM, <grass-user-request@lists.osgeo.org> wrote:
Date: Thu, 21 Aug 2008 10:45:35 +0200
Subject: [GRASS-user] common legend for the set of maps
To: grass-user@lists.osgeo.org
Message-ID: <48AD2B2F.1080203@amu.edu.pl>
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
Hi
I have set of map with foolowing (example) ranges:
0.34-1.1
0.67-2.4
0.12-0.8
And I need common legend for that set i.e 0.12-2.4
I think I shoud create map with range of data 0.12-2.4 and use it as the
source to the legend
I tried with r.plane and r.mapcalc but it is difficult to adjust proper
values
any ideas? (or simple solution?)
Jarek
