[GRASS-user] Compilation error with i.atcorr
Hi
I am receiving a compilation error with the i.atcorr module:
/usr/local/src/grass6_devel/imagery/i.atcorr$ make
Makefile:15: warning: overriding commands for target
`/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/bin/i.atcorr'
../../include/Make/Module.make:15: warning: ignoring old commands for
target `/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/bin/i.atcorr'
c++ -I/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/include -g
-O2 -mtune=native -march=native -DPACKAGE=\""grassmods"\"
-I/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.cpp
main.cpp:181: error: size of array ‘tic’ is too large
main.cpp: In member function ‘TIMap::Position TIMap::search(float, float)’:
main.cpp:200: error: ‘tic’ was not declared in this scope
main.cpp: In member function ‘TransformInput TIMap::get(TIMap::Position)’:
main.cpp:206: error: ‘tic’ was not declared in this scope
main.cpp: In member function ‘void TIMap::add(TransformInput, float, float)’:
main.cpp:209: error: ‘tic’ was not declared in this scope
main.cpp: In function ‘Options define_options()’:
main.cpp:469: warning: deprecated conversion from string constant to ‘char*’
main.cpp:476: warning: deprecated conversion from string constant to ‘char*’
main.cpp:498: warning: deprecated conversion from string constant to ‘char*’
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
main.cpp in line 176 has: MAX_TICs = 8192. If I change this to:
MAX_TICs = 3072, the code compiles.
The maximum stack size on my machine seems fine:
$ ulimit -s
8192
Any ideas why I'm having trouble compiling i.atcorr?
Regards
Craig
grass 6.5 r37242
ubuntu 9.04
gcc 4.3
CXXFLAGS="-g -O2 -mtune=native -march=native"
Craig,
On Sat, May 16, 2009 at 11:19 AM, Craig Leat <craig.leat@gmail.com> wrote:
Hi
the problem is fixed: the recently increased cache did not fit
on 32bit CPUs but only on 64bit. Now it is reduced to
4096 and it compiles again on 32bit, too.
TODO: implement dynamically allocated arrays in the cache.
Best
Hi Markus
Craig Leat:
Markus Neteler:
Great to hear you tracked this one down quickly.
Thanks
Craig
