[GRASS-user] Compilation Errors Installing GRASS 70 on Centos 6.5
Upon running ‘make’, I get errors consistent with the message below.
Any clues as to the source of the Error 1 messages, and what the fix is?
Thanks
Mark
make -C v.centroids || echo /home/grass/grass70/releasebranch_7_0/scripts/v.centroids >> /home/grass/grass70/releasebranch_7_0/error.log
make[3]: Entering directory /home/grass/grass70/releasebranch_7_0/scripts/v.centroids' if [ "/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/scripts/v.centroids" != "" ] ; then GISRC=/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70 GISBASE=/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu PATH="/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/bin:/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/bin:/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/scripts:$PATH" PYTHONPATH="/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/etc/python:/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/bin:/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/scripts:/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/lib:/home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/lib:" LC_ALL=C /home/grass/grass70/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/scripts/v.centroids --html-description < /dev/null | grep -v '</body>\|</html>' > v.centroids.tmp.html ; fi make[3]: *** [v.centroids.tmp.html] Error 1 rm v.centroids.tmp.html make[3]: Leaving directory /home/grass/grass70/releasebranch_7_0/scripts/v.centroids’
#Essentially the same errors for………
Errors in:
/home/grass/grass70/releasebranch_7_0/scripts/d.correlate
/home/grass/grass70/releasebranch_7_0/scripts/d.out.file
/home/grass/grass70/releasebranch_7_0/scripts/d.polar
/home/grass/grass70/releasebranch_7_0/scripts/d.rast.edit
/home/grass/grass70/releasebranch_7_0/scripts/d.rast.leg
/home/grass/grass70/releasebranch_7_0/scripts/d.redraw
/home/grass/grass70/releasebranch_7_0/scripts/d.shadedmap
/home/grass/grass70/releasebranch_7_0/scripts/d.vect.thematic
/home/grass/grass70/releasebranch_7_0/scripts/db.dropcolumn
/home/grass/grass70/releasebranch_7_0/scripts/db.droptable
/home/grass/grass70/releasebranch_7_0/scripts/db.in.ogr
/home/grass/grass70/releasebranch_7_0/scripts/db.out.ogr
/home/grass/grass70/releasebranch_7_0/scripts/db.test
/home/grass/grass70/releasebranch_7_0/scripts/g.extension.all
/home/grass/grass70/releasebranch_7_0/scripts/g.manual
/home/grass/grass70/releasebranch_7_0/scripts/i.colors.enhance
/home/grass/grass70/releasebranch_7_0/scripts/i.image.mosaic
/home/grass/grass70/releasebranch_7_0/scripts/i.in.spotvgt
/home/grass/grass70/releasebranch_7_0/scripts/i.oif
/home/grass/grass70/releasebranch_7_0/scripts/i.pansharpen
/home/grass/grass70/releasebranch_7_0/scripts/i.spectral
/home/grass/grass70/releasebranch_7_0/scripts/i.tasscap
/home/grass/grass70/releasebranch_7_0/scripts/m.proj
/home/grass/grass70/releasebranch_7_0/scripts/r.blend
/home/grass/grass70/releasebranch_7_0/scripts/r.buffer.lowmem
/home/grass/grass70/releasebranch_7_0/scripts/r.colors.stddev
/home/grass/grass70/releasebranch_7_0/scripts/r.fillnulls
/home/grass/grass70/releasebranch_7_0/scripts/r.grow
/home/grass/grass70/releasebranch_7_0/scripts/r.in.aster
/home/grass/grass70/releasebranch_7_0/scripts/r.in.srtm
/home/grass/grass70/releasebranch_7_0/scripts/r.in.wms
/home/grass/grass70/releasebranch_7_0/scripts/r.mask
/home/grass/grass70/releasebranch_7_0/scripts/r.out.xyz
/home/grass/grass70/releasebranch_7_0/scripts/r.pack
/home/grass/grass70/releasebranch_7_0/scripts/r.plane
/home/grass/grass70/releasebranch_7_0/scripts/r.reclass.area
/home/grass/grass70/releasebranch_7_0/scripts/r.rgb
/home/grass/grass70/releasebranch_7_0/scripts/r.tileset
/home/grass/grass70/releasebranch_7_0/scripts/r.unpack
/home/grass/grass70/releasebranch_7_0/scripts/r3.in.xyz
/home/grass/grass70/releasebranch_7_0/scripts/v.build.all
/home/grass/grass70/releasebranch_7_0/scripts/v.convert.all
/home/grass/grass70/releasebranch_7_0/scripts/v.db.addcolumn
/home/grass/grass70/releasebranch_7_0/scripts/v.db.addtable
#The steps I followed to this point:
#Instructions for installing the dependencies with a couple of additional packages needed
#http://grasswiki.osgeo.org/wiki/Compile_and_Install#CentOS
#yum -y install readline readline-devel
cd /home/grass/grass70/releasebranch_7_0
CFLAGS=“-g” ./configure
–enable-debug
–with-cxx
–without-ffmpeg
–with-gdal=/usr/bin/gdal-config
–with-geos
–with-readline
–with-freetype=yes
–with-freetype-includes=“/usr/include/freetype2/”
–enable-largefile=yes
–with-proj-share=/usr/share/proj/
–with-geos=/usr/bin/geos-config
–with-cairo
–with-tcltk-includes=“/usr/lib64/tcl8.5/”
–with-wxwidgets=/usr/bin/wx-config
–with-postgres=yes
–with-postgres-libs=“/usr/pgsql-9.3/lib/”
–with-postgres-includes=“/usr/pgsql-9.3/include/”
–with-sqlite=yes
–with-python=yes
–with-opengl-libs=“/usr/include/GL”
–without-mysql \
GRASS is now configured for: x86_64-unknown-linux-gnu
Source directory: /home/grass/grass70/releasebranch_7_0
Build directory: /home/grass/grass70/releasebranch_7_0
Installation directory: ${prefix}/grass-7.0.0svn
Startup script in directory:${exec_prefix}/bin
C compiler: gcc -g
C++ compiler: c++ -g -O2
Building shared libraries: yes
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
BLAS support: no
C++ support: yes
Cairo support: yes
DWG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: yes
LAPACK support: no
Large File support (LFS): yes
libLAS support: no
MySQL support: no
NetCDF support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenCL support: no
OpenGL support: yes
OpenMP support: no
PNG support: yes
POSIX thread support: no
PostgreSQL support: yes
Readline support: yes
Regex support: yes
SQLite support: yes
TIFF support: yes
wxWidgets support: yes
X11 support: yes
