[GRASS-user] Compilation failure in lib/gis/grassinit.c
CVS updated this afternoon and got a compilation failure in lib/gis/gisinit.c:
gisinit.c: In function `G_gisinit':
gisinit.c:40: error: `EXIT_FAILURE' undeclared (first use in this function)
gisinit.c:40: error: (Each undeclared identifier is reported only once
gisinit.c:40: error: for each function it appears in.)
and in several places in that file. That resulted in a complete failure of
all grass modules to build (trying to link to the library that failed).
Turns out that on FreeBSD you need to include stdlib.h in order to get
EXIT_FAILURE defined.
Adding #include <stdlib.h> before all the other includes fixed the whole thing.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
Fixed in CVS.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
