[renaming subject]
Seb wrote:
Trying to compile a module (v.in.gshhs) following these
instructions I did (first relevant output lines only):---<--------------------cut
here---------------start------------------->---
$ sudo make MODULE_TOPDIR=/usr/lib/grass64
mkdir -p
/build/buildd/grass-6.4.0~rc4/bin.x86_64-pc-linux-gnu
mkdir -p
/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/include/grass
mkdir -p
/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/lib
mkdir -p
/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/bin
mkdir -p
/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/etc
mkdir -p
/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/driver
mkdir -p
/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/driver/db
mkdir -p
/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/fonts
test -d OBJ.x86_64-pc-linux-gnu || mkdir -p
gcc
-I/build/buildd/grass-6.4.0~rc4/dist.x86_64-pc-linux-gnu/include
-Wall -g -O -I/usr/include/gdal
-DPACKAGE=\""grassmods"\" -I/usr/include/gdal
-o OBJ.x86_64-pc-linux-gnu/main.o -c main.c
main.c:30:23: error: grass/gis.h: No such file or
directory
main.c:31:24: error: grass/dbmi.h: No such file or
directory
main.c:32:24: error: grass/Vect.h: No such file or
directory
main.c:33:29: error: grass/gprojects.h: No such file or
directory
main.c:34:27: error: grass/glocale.h: No such file or
directory
here---------------end--------------------->---This is in Debian sid AMD64 (with grass-dev installeds, I
don't understand why gis.h is not found),
it should be there,
http://packages.debian.org/sid/i386/grass-dev/filelist
ls will confirm
where the /build path doesn't exist.
What variable needs to be passed to 'make' to set that
/build path so as not to create such top level directories
beyond GRASS that might pollute the system? Thanks.
is some enviro variable missing so that $VARIABLE/build/.../
becomes ""/build/... which tries to create a subdir off the
root dir which fails for a normal user account? (and since it
is broken, please don't try as root because who knows what
will happen
Hamish
