[GRASS-user] Compile GRASS GIS 7
Hello All:
I am using the instructions here: http://grasswiki.osgeo.org/wiki/Compile_and_Install
To compile GRASS 7 latest source code with svn up for SL Linux 6.5.
I have errors in what seem to be all directories. I will provide the transcript of make if necessary.
Thanks for all of the help.
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
http://www.auburn.edu/~sas0025
Let’s not spend our time and resources thinking about things that are so little or so large that all they really do for us is puff us up and make us feel like gods. We are mammals, and have not exhausted the annoying little problems of being mammals.
-K. Mullis
“A big computer, a complex algorithm and a long time does not equal science.”
-Robert Gentleman
Hi Stephen,
On Sat, Oct 11, 2014 at 5:42 PM, stephen sefick <ssefick@gmail.com> wrote:
Hello All:
It is quite hard to say what it is wrong, without see at least one error...
So please enter in one of the directory that give you some errors and
paste the error here.
Pietro
On 2014-10-11 17:42, stephen sefick wrote:
Hello All:
Wild guess: see if a "make clean" will make a difference.
Hermann
Stephen,
This is what I use on my Ubuntu Linux box:
First get the need libs:
sudo apt-get install
build-essential
make flex bison gcc libgcc1 g++ cmake ccache
python python-dev python-qt4 python-qt4-dev
python-opengl
python-wxversion python-wxtools python-wxgtk2.8
python-dateutil libgsl0-dev python-numpy
wx2.8-headers wx-common libwxgtk2.8-dev libwxgtk2.8-dbg
libwxbase2.8-dev libwxbase2.8-dbg
libncurses5-dev
zlib1g-dev gettext
libtiff4-dev
tcl8.5-dev tk8.5-dev
libcairo2 libcairo2-dev
sqlite3 libsqlite3-dev
libpq-dev
libreadline6 libreadline6-dev libfreetype6-dev
txt2tags
libfftw3-3 libfftw3-dev
libqt4-core libqt4-dbg libqt4-dev libqt4-gui libqt4-sql libqt4-qt3support
lsb-qt4 qt4-designer qt4-dev-tools qt4-doc qt4-qtconfig
libapt-pkg-perl resolvconf
libjasper-dev
ruby
subversion
libavcodec-dev
libxmu-dev
libavformat-dev libswscale-dev
checkinstall
libglu1-mesa-dev libxmu-dev
Configure, followed by make and make install:
./configure --with-opengl-includes=/usr/include/GL --enable-64bit --with-cxx --with-readline --with-freetype=yes --with-freetype-includes=/usr/include/freetype2/ --enable-largefile=yes --with-opengl-libs=/usr/lib --with-geos=/usr/local/bin/geos-config --with-tcltk-includes=/usr/local/include --with-tcltk-libs=/usr/local/lib --with-sqlite --with-sqlite-includes=/usr/local/include --with-sqlite-libs=/usr/local/lib --with-postgres --with-postgres-includes=/usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib --with-python --with-wxwidgets=/usr/bin/wx-config --with-proj-includes=/usr/local/include --with-proj-libs=/usr/local/lib --with-proj-share=/usr/local/share/proj --with-gdal=/usr/local/bin/gdal-config --with-proj-includes=/usr/local/include --with-proj-libs=/usr/local/lib --with-netcdf=/usr/local/bin/nc-config --with-blas-libs=/usr/local/lib --with-blas-includes=/usr/local/include/liblas --with-liblas=/usr/local/bin/liblas-config
Tom
On Sat, Oct 11, 2014 at 9:42 AM, stephen sefick <ssefick@gmail.com> wrote:
Hello All:
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
-K. Mullis
-Robert Gentleman
grass-user mailing list
grass-user@lists.osgeo.org
Stephen,
   I've had that on occassion and it turned out to be conflicts between wxGTK
and wxPython. Currently installed are wxGTK-2.8.12-i486-3_SBo and
wxPython-3.0.1.1-i486-1_SBo, no wxGTK3.
   If you have no such conflicts, then perhaps a message with the errors
(from the last back a few) will help.
Rich
Please let me know if y’all need anything else. Thanks for all of the help!
GRASS GIS compilation log
On Sat, Oct 11, 2014 at 6:22 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Stephen,
I’ve had that on occassion and it turned out to be conflicts between wxGTK
Rich
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
-K. Mullis
-Robert Gentleman
On Mon, Oct 13, 2014 at 3:31 PM, stephen sefick <ssefick@gmail.com> wrote:
Please let me know if y'all need anything else. Thanks for all of the help!
We need to know what happens *inside* the subdirectories :slight_smile:
Started compilation: Mon Oct 13 08:08:20 CDT 2014
Errors in:
/home/USER/source/grass/grass7/tools/timer
cd /home/USER/source/grass/grass7/tools/timer
make
--> which error?
/home/USER/source/grass/grass7/lib/raster
cd /home/USER/source/grass/grass7/lib/raster
make
--> which error?
The others may depend on this initial problems, so let's start with
the first issues.
Stephen,
Almost seems as though there are permissions problems; are you doing this as yourself (your login) or root? Also, what is the result of ./configure?
Very odd results!
Tom
Errors in:
/home/USER/source/grass/grass7/lib/pngdriver
/home/USER/source/grass/grass7/lib/psdriver
/home/USER/source/grass/grass7/lib/htmldriver
/home/USER/source/grass/grass7/lib/cairodriver
/home/USER/source/grass/grass7/lib/display
/home/USER/source/grass/grass7/lib/gtcltk
/home/USER/source/grass/grass7/lib/form
/home/USER/source/grass/grass7/lib/vector/diglib
/home/USER/source/grass/grass7/lib/vector/Vlib
/home/USER/source/grass/grass7/lib/vector/neta
/home/USER/source/grass/grass7/lib/vector/vedit
/home/USER/source/grass/grass7/lib/imagery
/home/USER/source/grass/grass7/lib/cluster
/home/USER/source/grass/grass7/lib/sites
/home/USER/source/grass/grass7/lib/rst/interp_float
/home/USER/source/grass/grass7/lib/lidar
/home/USER/source/grass/grass7/lib/raster3d
/home/USER/source/grass/grass7/lib/gpde
/home/USER/source/grass/grass7/lib/init
/home/USER/source/grass/grass7/lib/stats
/home/USER/source/grass/grass7/lib/ogsf
/home/USER/source/grass/grass7/lib/nviz
/home/USER/source/grass/grass7/lib/temporal/t.connect
/home/USER/source/grass/grass7/lib/manage
/home/USER/source/grass/grass7/db/drivers/postgres
/home/USER/source/grass/grass7/db/drivers/sqlite
/home/USER/source/grass/grass7/db/drivers/dbf
/home/USER/source/grass/grass7/db/drivers/ogr
/home/USER/source/grass/grass7/db/db.columns
/home/USER/source/grass/grass7/db/db.connect
/home/USER/source/grass/grass7/db/db.copy
/home/USER/source/grass/grass7/db/db.createdb
/home/USER/source/grass/grass7/db/db.databases
/home/USER/source/grass/grass7/db/db.describe
/home/USER/source/grass/grass7/db/db.login
/home/USER/source/grass/grass7/db/db.drivers
/home/USER/source/grass/grass7/db/db.dropdb
/home/USER/source/grass/grass7/db/db.tables
/home/USER/source/grass/grass7/db/db.select
/home/USER/source/grass/grass7/db/db.execute
/home/USER/source/grass/grass7/display/d.colortable
/home/USER/source/grass/grass7/display/d.barscale
/home/USER/source/grass/grass7/display/d.erase
/home/USER/source/grass/grass7/display/d.font
/home/USER/source/grass/grass7/display/d.fontlist
/home/USER/source/grass/grass7/display/d.colorlist
/home/USER/source/grass/grass7/display/d.geodesic
/home/USER/source/grass/grass7/display/d.grid
/home/USER/source/grass/grass7/display/d.graph
/home/USER/source/grass/grass7/display/d.his
/home/USER/source/grass/grass7/display/d.histogram
/home/USER/source/grass/grass7/display/d.info
/home/USER/source/grass/grass7/display/d.labels
/home/USER/source/grass/grass7/display/d.legend
/home/USER/source/grass/grass7/display/d.linegraph
/home/USER/source/grass/grass7/display/d.profile
/home/USER/source/grass/grass7/display/d.mon
/home/USER/source/grass/grass7/display/d.rast
/home/USER/source/grass/grass7/display/d.path
/home/USER/source/grass/grass7/display/d.rast.arrow
/home/USER/source/grass/grass7/display/d.rast.num
/home/USER/source/grass/grass7/display/d.rgb
/home/USER/source/grass/grass7/display/d.title
/home/USER/source/grass/grass7/display/d.rhumbline
/home/USER/source/grass/grass7/display/d.text
/home/USER/source/grass/grass7/display/d.vect
/home/USER/source/grass/grass7/display/d.vect.chart
/home/USER/source/grass/grass7/display/d.thematic.area
/home/USER/source/grass/grass7/display/d.where
/home/USER/source/grass/grass7/general/g.dirseps
/home/USER/source/grass/grass7/general/g.copy
/home/USER/source/grass/grass7/general/g.cairocomp
/home/USER/source/grass/grass7/general/g.access
/home/USER/source/grass/grass7/general/g.findetc
/home/USER/source/grass/grass7/general/g.filename
/home/USER/source/grass/grass7/general/g.findfile
/home/USER/source/grass/grass7/general/g.gisenv
/home/USER/source/grass/grass7/general/g.list
/home/USER/source/grass/grass7/general/g.gui
/home/USER/source/grass/grass7/general/g.mapset
/home/USER/source/grass/grass7/general/g.mapsets
/home/USER/source/grass/grass7/general/g.mkfontcap
/home/USER/source/grass/grass7/general/g.message
/home/USER/source/grass/grass7/general/g.mlist
/home/USER/source/grass/grass7/general/g.mremove
/home/USER/source/grass/grass7/general/g.pnmcomp
/home/USER/source/grass/grass7/general/g.ppmtopng
/home/USER/source/grass/grass7/general/g.parser
/home/USER/source/grass/grass7/general/g.rename
/home/USER/source/grass/grass7/general/g.tempfile
/home/USER/source/grass/grass7/general/g.region
/home/USER/source/grass/grass7/general/g.version
/home/USER/source/grass/grass7/general/g.remove
/home/USER/source/grass/grass7/general/g.proj
/home/USER/source/grass/grass7/general/manage/lister
/home/USER/source/grass/grass7/raster
/home/USER/source/grass/grass7/raster3d/r3.cross.rast
/home/USER/source/grass/grass7/raster3d/r3.gwflow
/home/USER/source/grass/grass7/raster3d/r3.in.bin
/home/USER/source/grass/grass7/raster3d/r3.gradient
/home/USER/source/grass/grass7/raster3d/r3.in.ascii
/home/USER/source/grass/grass7/raster3d/r3.info
/home/USER/source/grass/grass7/raster3d/r3.mkdspf
/home/USER/source/grass/grass7/raster3d/r3.mask
/home/USER/source/grass/grass7/raster3d/r3.neighbors
/home/USER/source/grass/grass7/raster3d/r3.out.ascii
/home/USER/source/grass/grass7/raster3d/r3.null
/home/USER/source/grass/grass7/raster3d/r3.in.v5d
/home/USER/source/grass/grass7/raster3d/r3.out.v5d
/home/USER/source/grass/grass7/raster3d/r3.out.vtk
/home/USER/source/grass/grass7/raster3d/r3.out.bin
/home/USER/source/grass/grass7/raster3d/r3.retile
/home/USER/source/grass/grass7/raster3d/r3.stats
/home/USER/source/grass/grass7/raster3d/r3.to.rast
/home/USER/source/grass/grass7/raster3d/r3.support
/home/USER/source/grass/grass7/raster3d/r3.timestamp
/home/USER/source/grass/grass7/raster3d/r3.flow
/home/USER/source/grass/grass7/vector/v.buffer
/home/USER/source/grass/grass7/vector/v.build
/home/USER/source/grass/grass7/vector/v.category
/home/USER/source/grass/grass7/vector/v.build.polylines
/home/USER/source/grass/grass7/vector/v.colors
/home/USER/source/grass/grass7/vector/v.clean
/home/USER/source/grass/grass7/vector/v.class
/home/USER/source/grass/grass7/vector/v.colors.out
/home/USER/source/grass/grass7/vector/v.db.connect
/home/USER/source/grass/grass7/vector/v.convert
/home/USER/source/grass/grass7/vector/v.db.select
/home/USER/source/grass/grass7/vector/v.delaunay
/home/USER/source/grass/grass7/vector/v.distance
/home/USER/source/grass/grass7/vector/v.drape
/home/USER/source/grass/grass7/vector/v.edit
/home/USER/source/grass/grass7/vector/v.extract
/home/USER/source/grass/grass7/vector/v.extrude
/home/USER/source/grass/grass7/vector/v.hull
/home/USER/source/grass/grass7/vector/v.info
/home/USER/source/grass/grass7/vector/v.in.db
/home/USER/source/grass/grass7/vector/v.in.ascii
/home/USER/source/grass/grass7/vector/v.generalize
/home/USER/source/grass/grass7/vector/v.in.dxf
/home/USER/source/grass/grass7/vector/v.kernel
/home/USER/source/grass/grass7/vector/v.in.sites
/home/USER/source/grass/grass7/vector/v.kcv
/home/USER/source/grass/grass7/vector/v.in.region
/home/USER/source/grass/grass7/vector/v.lidar.edgedetection
/home/USER/source/grass/grass7/vector/v.label
/home/USER/source/grass/grass7/vector/v.lidar.correction
/home/USER/source/grass/grass7/vector/v.mkgrid
/home/USER/source/grass/grass7/vector/v.proj
/home/USER/source/grass/grass7/vector/v.lidar.growing
/home/USER/source/grass/grass7/vector/v.neighbors
/home/USER/source/grass/grass7/vector/v.net.alloc
/home/USER/source/grass/grass7/vector/v.net.allpairs
/home/USER/source/grass/grass7/vector/v.net.centrality
/home/USER/source/grass/grass7/vector/v.net.bridge
/home/USER/source/grass/grass7/vector/v.net.components
/home/USER/source/grass/grass7/vector/v.net.distance
/home/USER/source/grass/grass7/vector/v.net.flow
/home/USER/source/grass/grass7/vector/v.net.iso
/home/USER/source/grass/grass7/vector/v.net.path
/home/USER/source/grass/grass7/vector/v.net.salesman
/home/USER/source/grass/grass7/vector/v.net.connectivity
/home/USER/source/grass/grass7/vector/v.net.spanningtree
/home/USER/source/grass/grass7/vector/v.net.steiner
/home/USER/source/grass/grass7/vector/v.net.visibility
/home/USER/source/grass/grass7/vector/v.net.timetable
/home/USER/source/grass/grass7/vector/v.lrs/v.lrs.segment
/home/USER/source/grass/grass7/vector/v.lrs/v.lrs.create
/home/USER/source/grass/grass7/vector/v.normal
/home/USER/source/grass/grass7/vector/v.out.dxf
/home/USER/source/grass/grass7/vector/v.out.ascii
/home/USER/source/grass/grass7/vector/v.out.pov
/home/USER/source/grass/grass7/vector/v.lrs/v.lrs.label
/home/USER/source/grass/grass7/vector/v.out.svg
/home/USER/source/grass/grass7/vector/v.outlier
/home/USER/source/grass/grass7/vector/v.lrs/v.lrs.where
/home/USER/source/grass/grass7/vector/v.out.vtk
/home/USER/source/grass/grass7/vector/v.overlay
/home/USER/source/grass/grass7/vector/v.perturb
/home/USER/source/grass/grass7/vector/v.split
/home/USER/source/grass/grass7/vector/v.parallel
/home/USER/source/grass/grass7/vector/v.qcount
/home/USER/source/grass/grass7/vector/v.random
/home/USER/source/grass/grass7/vector/v.patch
/home/USER/source/grass/grass7/vector/v.rectify
/home/USER/source/grass/grass7/vector/v.sample
/home/USER/source/grass/grass7/vector/v.reclass
/home/USER/source/grass/grass7/vector/v.select
/home/USER/source/grass/grass7/vector/v.surf.bspline
/home/USER/source/grass/grass7/vector/v.support
/home/USER/source/grass/grass7/vector/v.surf.idw
/home/USER/source/grass/grass7/vector/v.transform
/home/USER/source/grass/grass7/vector/v.segment
/home/USER/source/grass/grass7/vector/v.timestamp
/home/USER/source/grass/grass7/vector/v.to.3d
/home/USER/source/grass/grass7/vector/v.surf.rst
/home/USER/source/grass/grass7/vector/v.to.db
/home/USER/source/grass/grass7/vector/v.to.rast
/home/USER/source/grass/grass7/vector/v.to.rast3
/home/USER/source/grass/grass7/vector/v.to.points
/home/USER/source/grass/grass7/vector/v.type
/home/USER/source/grass/grass7/vector/v.univar
/home/USER/source/grass/grass7/vector/v.what
/home/USER/source/grass/grass7/vector/v.voronoi
/home/USER/source/grass/grass7/vector/v.what.rast
/home/USER/source/grass/grass7/vector/v.vect.stats
/home/USER/source/grass/grass7/vector/v.out.ogr
/home/USER/source/grass/grass7/vector/v.vol.rst
/home/USER/source/grass/grass7/vector/v.in.ogr
/home/USER/source/grass/grass7/vector/v.external
/home/USER/source/grass/grass7/vector/v.external.out
/home/USER/source/grass/grass7/misc/m.cogo
/home/USER/source/grass/grass7/misc/m.measure
/home/USER/source/grass/grass7/misc/m.nviz.script
/home/USER/source/grass/grass7/misc/m.transform
/home/USER/source/grass/grass7/misc/m.nviz.image
/home/USER/source/grass/grass7/imagery/i.albedo
/home/USER/source/grass/grass7/imagery/i.aster.toar
/home/USER/source/grass/grass7/imagery/i.biomass
/home/USER/source/grass/grass7/imagery/i.atcorr
/home/USER/source/grass/grass7/imagery/i.cca
/home/USER/source/grass/grass7/imagery/i.eb.evapfr
/home/USER/source/grass/grass7/imagery/i.cluster
/home/USER/source/grass/grass7/imagery/i.eb.eta
/home/USER/source/grass/grass7/imagery/i.eb.h_SEBAL01
/home/USER/source/grass/grass7/imagery/i.eb.netrad
/home/USER/source/grass/grass7/imagery/i.eb.soilheatflux
/home/USER/source/grass/grass7/imagery/i.evapo.mh
/home/USER/source/grass/grass7/imagery/i.evapo.pm
/home/USER/source/grass/grass7/imagery/i.evapo.pt
/home/USER/source/grass/grass7/imagery/i.emissivity
/home/USER/source/grass/grass7/imagery/i.evapo.time
/home/USER/source/grass/grass7/imagery/i.gensig
/home/USER/source/grass/grass7/imagery/i.find
/home/USER/source/grass/grass7/imagery/i.his.rgb
/home/USER/source/grass/grass7/imagery/i.landsat.toar
/home/USER/source/grass/grass7/imagery/i.gensigset
/home/USER/source/grass/grass7/imagery/i.latlong
/home/USER/source/grass/grass7/imagery/i.group
/home/USER/source/grass/grass7/imagery/i.maxlik
/home/USER/source/grass/grass7/imagery/i.rectify
/home/USER/source/grass/grass7/imagery/i.landsat.acca
/home/USER/source/grass/grass7/imagery/i.modis.qc
/home/USER/source/grass/grass7/imagery/i.sunhours
/home/USER/source/grass/grass7/imagery/i.rgb.his
/home/USER/source/grass/grass7/imagery/i.smap
/home/USER/source/grass/grass7/imagery/i.target
/home/USER/source/grass/grass7/imagery/i.pca
/home/USER/source/grass/grass7/imagery/i.vi
/home/USER/source/grass/grass7/ps/ps.map
/home/USER/source/grass/grass7/scripts/d.correlate
/home/USER/source/grass/grass7/scripts/d.out.file
/home/USER/source/grass/grass7/scripts/d.polar
/home/USER/source/grass/grass7/scripts/d.rast.leg
/home/USER/source/grass/grass7/scripts/d.redraw
/home/USER/source/grass/grass7/scripts/d.shadedmap
/home/USER/source/grass/grass7/scripts/db.dropcolumn
/home/USER/source/grass/grass7/scripts/d.vect.thematic
/home/USER/source/grass/grass7/scripts/db.droptable
/home/USER/source/grass/grass7/scripts/db.in.ogr
/home/USER/source/grass/grass7/scripts/db.out.ogr
/home/USER/source/grass/grass7/scripts/db.test
/home/USER/source/grass/grass7/scripts/db.univar
/home/USER/source/grass/grass7/scripts/g.manual
/home/USER/source/grass/grass7/scripts/g.extension.all
/home/USER/source/grass/grass7/scripts/i.image.mosaic
/home/USER/source/grass/grass7/scripts/i.in.spotvgt
/home/USER/source/grass/grass7/scripts/i.oif
/home/USER/source/grass/grass7/scripts/i.colors.enhance
/home/USER/source/grass/grass7/scripts/i.spectral
/home/USER/source/grass/grass7/scripts/i.tasscap
/home/USER/source/grass/grass7/scripts/m.proj
/home/USER/source/grass/grass7/scripts/r.blend
/home/USER/source/grass/grass7/scripts/r.buffer.lowmem
/home/USER/source/grass/grass7/scripts/r.colors.stddev
/home/USER/source/grass/grass7/scripts/r.fillnulls
/home/USER/source/grass/grass7/scripts/r.in.aster
/home/USER/source/grass/grass7/scripts/d.rast.edit
/home/USER/source/grass/grass7/scripts/r.in.srtm
/home/USER/source/grass/grass7/scripts/r.grow
/home/USER/source/grass/grass7/scripts/r.mask
/home/USER/source/grass/grass7/scripts/r.in.wms
/home/USER/source/grass/grass7/scripts/r.out.xyz
/home/USER/source/grass/grass7/scripts/r.plane
/home/USER/source/grass/grass7/scripts/r.reclass.area
/home/USER/source/grass/grass7/scripts/r.pack
/home/USER/source/grass/grass7/scripts/r.rgb
/home/USER/source/grass/grass7/scripts/r.tileset
/home/USER/source/grass/grass7/scripts/r.unpack
/home/USER/source/grass/grass7/scripts/v.centroids
/home/USER/source/grass/grass7/scripts/v.convert.all
/home/USER/source/grass/grass7/scripts/v.build.all
/home/USER/source/grass/grass7/scripts/v.db.addcolumn
/home/USER/source/grass/grass7/scripts/r3.in.xyz
/home/USER/source/grass/grass7/scripts/v.db.addtable
/home/USER/source/grass/grass7/scripts/i.pansharpen
/home/USER/source/grass/grass7/scripts/v.db.join
/home/USER/source/grass/grass7/scripts/v.db.droptable
/home/USER/source/grass/grass7/scripts/v.db.dropcolumn
/home/USER/source/grass/grass7/scripts/v.db.droprow
/home/USER/source/grass/grass7/scripts/v.db.renamecolumn
/home/USER/source/grass/grass7/scripts/v.db.reconnect.all
/home/USER/source/grass/grass7/scripts/v.db.update
/home/USER/source/grass/grass7/scripts/v.db.univar
/home/USER/source/grass/grass7/scripts/v.dissolve
/home/USER/source/grass/grass7/scripts/v.in.geonames
/home/USER/source/grass/grass7/scripts/v.in.e00
/home/USER/source/grass/grass7/scripts/v.in.gns
/home/USER/source/grass/grass7/scripts/v.in.lines
/home/USER/source/grass/grass7/scripts/v.in.wfs
/home/USER/source/grass/grass7/scripts/v.in.mapgen
/home/USER/source/grass/grass7/scripts/v.rast.stats
/home/USER/source/grass/grass7/scripts/v.out.gps
/home/USER/source/grass/grass7/scripts/v.report
/home/USER/source/grass/grass7/scripts/v.pack
/home/USER/source/grass/grass7/scripts/v.to.lines
/home/USER/source/grass/grass7/scripts/v.what.vect
/home/USER/source/grass/grass7/scripts/v.unpack
/home/USER/source/grass/grass7/scripts/wxpyimgview
/home/USER/source/grass/grass7/scripts/v.krige
/home/USER/source/grass/grass7/temporal/t.connect
/home/USER/source/grass/grass7/temporal/t.create
/home/USER/source/grass/grass7/temporal/t.support
/home/USER/source/grass/grass7/temporal/t.topology
/home/USER/source/grass/grass7/temporal/t.list
/home/USER/source/grass/grass7/temporal/t.info
/home/USER/source/grass/grass7/temporal/t.merge
/home/USER/source/grass/grass7/temporal/t.sample
/home/USER/source/grass/grass7/temporal/t.unregister
/home/USER/source/grass/grass7/temporal/t.register
/home/USER/source/grass/grass7/temporal/t.remove
/home/USER/source/grass/grass7/temporal/t.rast.accumulate
/home/USER/source/grass/grass7/temporal/t.rast.accdetect
/home/USER/source/grass/grass7/temporal/t.rast.aggregate.ds
/home/USER/source/grass/grass7/temporal/t.rast.colors
/home/USER/source/grass/grass7/temporal/t.rast.univar
/home/USER/source/grass/grass7/temporal/t.rast.to.rast3
/home/USER/source/grass/grass7/temporal/t.rast.list
/home/USER/source/grass/grass7/temporal/t.rast.mapcalc
/home/USER/source/grass/grass7/temporal/t.rast.mapcalc2
/home/USER/source/grass/grass7/temporal/t.rast.neighbors
/home/USER/source/grass/grass7/temporal/t.rast.series
/home/USER/source/grass/grass7/temporal/t.rast.export
/home/USER/source/grass/grass7/temporal/t.rast.out.vtk
/home/USER/source/grass/grass7/temporal/t.rast.import
/home/USER/source/grass/grass7/temporal/t.rast.gapfill
/home/USER/source/grass/grass7/temporal/t.rast.extract
/home/USER/source/grass/grass7/temporal/t.rast3d.list
/home/USER/source/grass/grass7/temporal/t.rast3d.extract
/home/USER/source/grass/grass7/temporal/t.rast3d.mapcalc
/home/USER/source/grass/grass7/temporal/t.select
/home/USER/source/grass/grass7/temporal/t.rast3d.univar
/home/USER/source/grass/grass7/temporal/t.rast3d.mapcalc2
/home/USER/source/grass/grass7/temporal/t.rename
/home/USER/source/grass/grass7/temporal/t.vect.db.select
/home/USER/source/grass/grass7/temporal/t.snap
/home/USER/source/grass/grass7/temporal/t.vect.list
/home/USER/source/grass/grass7/temporal/t.vect.extract
/home/USER/source/grass/grass7/temporal/t.shift
/home/USER/source/grass/grass7/temporal/t.vect.export
/home/USER/source/grass/grass7/temporal/t.vect.mapcalc
/home/USER/source/grass/grass7/temporal/t.vect.import
/home/USER/source/grass/grass7/temporal/t.vect.what.strds
/home/USER/source/grass/grass7/temporal/t.vect.observe.strds
/home/USER/source/grass/grass7/temporal/t.vect.univar
/home/USER/source/grass/grass7/visualization/xganim
/home/USER/source/grass/grass7/visualization/wximgview
/home/USER/source/grass/grass7/visualization/ximgview
/home/USER/source/grass/grass7/visualization/nviz
/home/USER/source/grass/grass7/man
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Oct 13 08:09:10 CDT 2014
make: *** [default] Error 1
/home/USER/source/grass/grass7/bin.x86_64-unknown-linux-gnu/grass70
make install-check-built
make[1]: Entering directory /home/USER/source/grass/grass7' make[1]: Leaving directory /home/USER/source/grass/grass7’
make install-check-parent
make install-check-writable
make install-check-prefix
make real-install
make[1]: Entering directory /home/USER/source/grass/grass7' tar cBCf /home/USER/source/grass/grass7/dist.x86_64-unknown-linux-gnu - . | tar xBCf /usr/local/grass-7.0.svn - 2>/dev/null rm /usr/local/grass-7.0.svn/grass70.tmp make /usr/local/bin/grass70 make[2]: Entering directory /home/USER/source/grass/grass7’
sed -e ‘s#’@GISBASE@‘#’/usr/local/grass-7.0.svn’#g
-e ‘s#’@LD_LIBRARY_PATH_VAR@‘#‘LD_LIBRARY_PATH’#g
-e ‘s#’@CONFIG_PROJSHARE@‘#’/usr/share/proj’#g
/home/USER/source/grass/grass7/dist.x86_64-unknown-linux-gnu/grass70.tmp > /usr/local/bin/grass70
chmod a+x /usr/local/bin/grass70
make[2]: Leaving directory /home/USER/source/grass/grass7' rm /usr/local/grass-7.0.svn/etc/fontcap rm: cannot remove /usr/local/grass-7.0.svn/etc/fontcap’: No such file or directory
make[1]: [real-install] Error 1 (ignored)
make /usr/local/grass-7.0.svn/etc/fontcap
make[2]: Entering directory /home/USER/source/grass/grass7' make[2]: *** No rule to make target /home/USER/source/grass/grass7/dist.x86_64-unknown-linux-gnu/etc/fontcap’, needed by /usr/local/grass-7.0.svn/etc/fontcap'. Stop. make[2]: Leaving directory /home/USER/source/grass/grass7’
make[1]: *** [real-install] Error 2
make[1]: Leaving directory `/home/USER/source/grass/grass7’
make: *** [install] Error 2
Stephen,
Rich
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
-K. Mullis
-Robert Gentleman
