[GRASS-user] compiling an addon in grass 7
Hi!
I would like to install r.refine addon in grass 7. I have the c/c++ code of r.refine and I installed grass 7 and grass-dev. When I compile it keeps giving me error about grass-src directory. I searched my ubuntu folders and I did not find anything like that. Looks like I need entire source not just header files to compile. I will try tomorrow but I am just wondering why should an addon require entire source to compile? Is it badly written addon or am i missing something?
Thanks
Shashank
Did you install grass-dev on your machine.
It will need it to compile the add-ons.
Try installing grass-dev as below;
> sudo apt-get install grass-dev
best
Venka
On 2015/05/31 14:28, skhare@hotmail.com wrote:
Hi!
      Thanks
      Shashank
grass-user mailing list
grass-user@lists.osgeo.org
On Sun, May 31, 2015 at 7:28 AM, <skhare@hotmail.com> wrote:
Hi!
Quick question: Is r.refine online available (for testing)? Do you refer to
https://github.com/jontodd/r.refine
It appears to be written for an older GRASS GIS version.
You can compile like this (example for path) as on my machine:
make MODULE_TOPDIR=$HOME/software/grass70
Indeed, you need to have the compiled GRASS GIS source code available for that.
will get the source code onto your computer.
However, the r.refine version needs to be GRASS GIS 7 ready, otherwise
it won't compile.
Best
I downloaded the source from https://github.com/jontodd/r.refine. I am willing to port it to grass 7 if i get help. I guess the author is not supporting it since there is no commit after 2006. This is my first project on Grass. Is there any tutorial/documentation on how to to write addons for grass 7? I developed a plugin for qgis and its really easy with so much documentation available online. I wish it were the case with Grass. But nonetheless I want to give Grass a serious try.
Will try with compiled source code today. When i installed grass-dev I do not see the source code of grass on my system. Which dir does it go to?
Thanks
Shashank
Date: Sun, 31 May 2015 14:03:10 +0200
Subject: Re: [GRASS-user] compiling an addon in grass 7
To: skhare@hotmail.com
CC: grass-user@lists.osgeo.org
Hi!
it won't compile.
Best
Great!
Yes, sure. It is written like any other GRASS GIS module.
Please let us know where you looked for it and didn't find it - I
would like to improve the documentation.
A good chance to make it better!
This depends on the package/distro. You can use your package manager
(apt-get or aptitude in your case) to see where the files of the
"grass-dev" package are on your machine.
HTH
I tried compiling r.refine with grass 7 but gcc could not find definition of Site_head struct. I looked into it and figured out that grass/site.h is missing. Where has it gone? I even downloaded the entire source code of 7.0.0 but even that does not have any file which contains definition of Site_head struct. Can someone enlighten me regarding “site” data structure. I believe site is a way of storing point type data.
Thanks in advance.
Shashank
Date: Sun, 31 May 2015 21:37:06 +0200
Great!
Please let us know where you looked for it and didn’t find it - I
“grass-dev” package are on your machine.
HTH
It has been eliminated many years back in the update to GRASS GIS 7
(or even 6, don't remember).
Site_head struct. Can someone enlighten me regarding "site" data structure.
Nowadays the vector library is used for that:
http://grass.osgeo.org/programming7/vectorlib.html
You may want to look at the source code of point related modules (see
keyword index of manual).
definition of
Actually quite recently:
https://trac.osgeo.org/grass/ticket/2440
structure.
On Tue, Jun 2, 2015 at 3:23 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
> definition of
Well, this is only the aftermath... The real updates from the sites to
the vector library happened way longer ago.
