[GRASS-user] Compiling GRAS on Windows- Log and error
Greetings
First of all, Thanks Martin Landa for helping me finding a package that I was not finding :slight_smile:
I have runned and performed all steps from http://trac.osgeo.org/grass/wiki/CompileOnWindows. now I am at 3. To compile, type in MSYS console:
cd /osgeo4w/usr/src/grass-6.4xxx (change to dir of the version you downloaded)
./mswindows/osgeo4w/package.sh
I have added r.example at raster folder and added r.example \ at Makefile inside raster folder.
It’s supposed to be installed into apps/grass/grass6.4.0svn but nothing was added there (I have OSGEO4W Desktop installation done in that folder so a few files are already available there).
This is the Configuration:
GRASS is now configured for: i686-pc-mingw32
Source directory:
Build directory: /c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12
Installation directory: ${prefix}/grass-6.4.0svn
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler:
Building shared libraries: yes
64bit support: no
OpenGL platform: Windows
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
NVIZ: yes
BLAS support: no
C++ support: no
Cairo support: no
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GLw support: no
JPEG support: yes
LAPACK support: no
Large File support (LFS): yes
Motif support: no
MySQL support: no
NLS support: yes
ODBC support: yes
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: yes
Python support: no
Readline support: no
SQLite support: yes
Tcl/Tk support: yes
wxWidgets support: no
TIFF support: yes
X11 support: no
And I got errors in all of these modules:
Following modules are missing the ‘description.html’ file in src code:
GRASS GIS compilation log
Started compilation: Mon Jun 14 15:18:37 GMTDT 2010
Errors in:
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/display/d.grid
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/display/d.where
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/general/g.proj
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/general/g.region
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/general/g.setproj
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/ps/ps.map
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.external
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.example
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.horizon
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.los
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.proj.seg
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.sun2
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.sunmask
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.in.gdal
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.out.gdal
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/vector/v.proj
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/vector/v.out.ogr
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/vector/v.in.ogr
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Jun 14 15:24:59 GMTDT 2010
make: *** [default] Error 1
And regarding the r.example I got this:
/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.external' r.example makefile:10: ../../../include/Make/Module.make: No such file or directory make[2]: *** No rule to make target …/…/…/include/Make/Module.make’. Stop.
make[2]: Entering directory /c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.example' make[2]: Leaving directory /c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.example’
My questions are:
  • Shouldn’t I have wxwidgets ON as well as python?
  • Why no module was added to my grass destination folder?
  • What happened with my r.example installation?
Thank you
Best regards,
Luisa
Luisa Peña wrote:
Errors in:
This suggests a problem with PROJ.
'make'.
Please do this.
`/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.external'
r.example
You need to adjust MODULE_TOPDIR in r.example/Makefile. Normally,
r.example is at docs/raster/r.example (3 levels deep). If you move it
to raster/r.example (2 levels deep), the relative path to the top of
the source tree has changed, so MODULE_TOPDIR (which is used to find
other files within the source tree) has to be changed.
- Shouldn't I have wxwidgets ON as well as python?
It's only needed for modules which use wxWidgets from C/C++, e.g. the
wxGUI vdigit module. This doesn't work on Windows at present. It isn't
needed for the wxPython GUI; that gets built and installed regardless
of which configure switches are used (obviously, you need Python and
wxPython in order to actually run the GUI).
Hi
Please do this.
I have done that and I got:
make -C r.example MODULE_TOPDIR=/c/osgeo4w/apps/grass/grass-6.4.0svn
make: Entering directory /c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.example' Makefile:10: /c/osgeo4w/apps/grass/grass-6.4.0svn/include/Make/Module.make: No such file or directory make: *** No rule to make target /c/osgeo4w/apps/grass/grass-6.4.0svn/include/Make/Module.make’. Stop.
make: Leaving directory `/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.example’
But then I installed grass-dev lib (from OSGEO4W), following a tip from Antonio, and I got a bit different result:
make: Entering directory /c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.example' make: stat:/d/progs/c/grass64/bin.i686-pc-mingw32: no medium mkdir -p /d/progs/c/grass64/bin.i686-pc-mingw32 mkdir: /d/progs/c/grass64/bin.i686-pc-mingw32’: no medium
make: *** [/d/progs/c/grass64/bin.i686-pc-mingw32] Error 1
1- Was it necessary to install gdal-dev lib? (because it was not listed in the Compiling in MS-Windows wiki)
2- I believe that the problem now is in include/Make/Platform definitions right?
2010/6/14 Glynn Clements <glynn@gclements.plus.com>
Luisa Peña wrote:
Errors in:
‘make’.
Please do this.
`/c/osgeo4w/download/GRASS_snapshot/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.external’
r.example
makefile:10: …/…/…/include/Make/Module.make: No such file or directory
It’s only needed for modules which use wxWidgets from C/C++, e.g. the
wxGUI vdigit module. This doesn’t work on Windows at present. It isn’t
> r.example
Normally, r.example is at docs/raster/r.example (3 levels deep). If
you move it to raster/r.example (2 levels deep), the relative path to
the top of the source tree has changed, so MODULE_TOPDIR (which is
used to find other files within the source tree) has to be changed.
also try using the full path name for MODULE_TOPDIR, not a ../.. relative
one.
H
run 'make'.
>Please do this.
Wrong directory. I was referring to the others, e.g.:
The r.example problem was caused by moving the r.example directory but
failing to adjust MODULE_TOPDIR.
Hi Glynn. As you saw from previous messages, my problem now is with libgrass_display.dll.
I saw a message that you sent to ML regarding this problem. Can it be related with prebinaries and MinGW packages version?
Here goes my versions of pre-built binaries:
BC- 1.06.2-bin
Bison- 2.1-bin
Bison-2.1-dep-bin
flex- 2.5.4a-1-bin
gettext-0.14.4-bin
gettext-0.14.4-bin
libiconv-1.9.2-1-bin
libintl-0.14.4-bin
libintl-0.14.4-lib
readline-5.0-1-bin
regex2.7-bin
Make Update version: make-3.81-MSYS-1.0.11-2
MinGW packages:
  • temp bugfix - DIDN’T USED
  • msysCORE-1.0.11-bin
  • binutils-2.19.1-mingw32-bin
  • gcc-core-3.4.5-20060117-3
  • gcc-g+±3.4.5-20060117-3
  • mingw32-make-3.81-20080326-3
  • mingwrt-3.15.2-mingw32-dev
  • mingw-utils-0.3
Anything that might be causing this problem? Or shoudl I use a older snapshot of GRASS?
  • w32api-3.13-mingw32-dev
Maybe. Everything stems from the linker crashing while trying to build
libgrass_psdriver. This is required by libgrass_raster, which is
required by all d.* modules (and also by libgrass_display).
The psdriver library hasn't changed much recently, so it's more likely
to be an issue with the specific version of MSys' binutils.
