hellik
1
since very long time (mainly working on the windows-platform)
I'm trying again compiling grass65svn on linux, here on my box the
fresh ubuntu 11.10.
my configure line is:
myricaria@myricaria-hp-pavilion-ze4900-PJ920EA-ABD:/usr/local/src/grass/grass6_devel$
./configure
--with-cxx
--with-sqlite
--with-cairo
--with-freetype
--with-nls
--with-read-line
--with-gdal=/usr/bin/gdal-config
--with-python=/usr/bin/python2.7-config
--with-geos=/usr/bin/geos-config
--with-freetype-includes=/usr/include/freetype2/
--with-proj-share=/usr/share/proj
I'm getting following:
configure: error: can not run ./config.sub
following http://code.google.com/p/bioapi-linux/issues/detail?id=2
there seems to be some issues with automake and connected things.
I'm a little bit confused, because on ubuntu 11.10, there are available
automake and connected things with version 1.09, 1.10, 1.11 ...
any hints?
Helmut
___________________________________________________________
SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
neteler
2
fresh ubuntu 11.10.
./configure
--with-cxx
--with-sqlite
--with-cairo
--with-freetype
--with-nls
--with-read-line
Please post also the lines before that.
not sure if that posting is relevant here...
any hints?
you need autoconf 2.13 (not 2.65) but both can be installed in parallel.
hellik
3
now tried with r49289 - grass/branches/develbranch_6
./configure
--with-cxx
--with-sqlite
--with-cairo
--with-freetype
--with-nls
--with-read-line
now tried with
myricaria@myricaria-hp-pavilion-ze4900-PJ920EA-ABD:/usr/local/src/grass6_devel$
./configure --with-cxx --with-sqlite --with-cairo --with-freetype
--with-proj-share=/usr/share/proj --with-geos=/usr/bin/geos-config
--with-gdal=/usr/bin/gdal-config --with-tcltk-includes=/usr/include/tcl8.5
--with-wxwidgets=/usr/bin/wx-config --with-nls
--with-python=/usr/bin/python-config
there are no lines before. should there be any?
I'm following:
http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu
and
http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu
...which one of above would be the recommended?
here are following autoconf-versions on the system
autoconfig 2.68-1ubuntu1 (oneiric)
autoconfig 2.13-60 (oneiric)
all the best
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/compiling-grass65svn-error-on-ubuntu-11-10-tp6967393p7010258.html
