Hi there
After successfully compiling grass7 svn on OSX, I’m trying to compile the add-on i.rotate.
My problem seems to be with python not recognizing 32/64 bits:
make GRASS_HOME=‘/Volumes/HDD/Users/guano/Documents/installs/GIS/grass/modbuild/module/i.rotate’ GRASS_APP=‘/Applications/GRASS-7.0.app/’
gcc -I/Volumes/HDD/Users/guano/Documents/installs/GIS/grass/modbuild/module/i.rotate/dist.i386-apple-darwin10.7.0/include -I/Applications/GRASS-7.0.app//Contents/MacOS/include -Os -fexceptions -arch i386 -arch x86_64 -DPACKAGE="“grassmods”" -I/Volumes/HDD/Users/guano/Documents/installs/GIS/grass/modbuild/module/i.rotate/dist.i386-apple-darwin10.7.0/include -I/Applications/GRASS-7.0.app//Contents/MacOS/include -o OBJ.i386-apple-darwin10.7.0/main.o -c main.c
main.c: In function ‘main’:
main.c:87: error: subscripted value is neither array nor pointer
main.c:89: error: subscripted value is neither array nor pointer
main.c:103: error: subscripted value is neither array nor pointer
main.c:111: error: subscripted value is neither array nor pointer
lipo: can’t figure out the architecture type of: /var/folders/gf/8bwpz0412gs7706j57hdyb4h0000gn/T//ccVKHaGQ.out
make: *** [OBJ.i386-apple-darwin10.7.0/main.o] Error 1
any hints are welcome
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
Nothing to do with python here. And I don't see any architecture problem (what you see is just what generally happens with a compilation error on OS X).
Also note that I removed the modbuild stuff from GRASS 7, in favor of g.extension (though g.extension has its own problems), and I don't know if the old modbuild will work properly with GRASS 7.
On Dec 2, 2012, at 12:35 PM, Carlos Grohmann wrote:
Hi there
After successfully compiling grass7 svn on OSX, I'm trying to compile the add-on i.rotate.
make GRASS_HOME='/Volumes/HDD/Users/guano/Documents/installs/GIS/grass/modbuild/module/i.rotate' GRASS_APP='/Applications/GRASS-7.0.app/'
gcc -I/Volumes/HDD/Users/guano/Documents/installs/GIS/grass/modbuild/module/i.rotate/dist.i386-apple-darwin10.7.0/include -I/Applications/GRASS-7.0.app//Contents/MacOS/include -Os -fexceptions -arch i386 -arch x86_64 -DPACKAGE=\""grassmods"\" -I/Volumes/HDD/Users/guano/Documents/installs/GIS/grass/modbuild/module/i.rotate/dist.i386-apple-darwin10.7.0/include -I/Applications/GRASS-7.0.app//Contents/MacOS/include -o OBJ.i386-apple-darwin10.7.0/main.o -c main.c
lipo: can't figure out the architecture type of: /var/folders/gf/8bwpz0412gs7706j57hdyb4h0000gn/T//ccVKHaGQ.out
best
Carlos
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
