[GRASS-user] Compiling the weekly source (configure bug?)
Hey all, I'm interested in making some changes to the GRASS core so I'm
trying to work with the latest source package. However, I'm having a hard
time getting it to install. It says it's unable to locate my FreeType
includes. I think that there's bug in the configure where someone forgot
to include "-I/usr/local/include/freetype2"
Thoughts on the problem and/or how to get this configured? Here's my
Terminal's text and a bunch of relevant info:
$ ./configure --enable-shared --prefix=/Applications --enable-macosx-app
--with-opengl=aqua && make && sudo make install
checking host system type... i386-apple-darwin9.7.0
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
[... snip ...]
checking for cairo_xlib_surface_create_with_xrender_format... yes
checking for cairo_xlib_surface_get_xrender_format... yes
checking whether to use FreeType... yes
checking for location of FreeType includes...
checking for ft2build.h... no
configure: error: *** Unable to locate FreeType includes.
$ freetype-config
Usage: freetype-config [OPTION]...
Get FreeType compilation and linking information.
Options:
  --prefix display `--prefix' value used for building the
                         FreeType library
  --prefix=PREFIX override `--prefix' value with PREFIX
  --exec-prefix display `--exec-prefix' value used for building
                         the FreeType library
  --exec-prefix=EPREFIX override `--exec-prefix' value with EPREFIX
  --version display libtool version of the FreeType library
  --ftversion display FreeType version number
  --libs display flags for linking with the FreeType library
  --libtool display library name for linking with libtool
  --cflags display flags for compiling with the FreeType
                         library
$ tail -n 20 config.log
configure:13590: checking for cairo.h
configure:13598: gcc -E -I/usr/local/include/cairo
-I/usr/local/include/pixman-1 -I/usr/local/include/freetype2
-I/usr/local/include -I/usr/local/include/libpng12 -I/usr/X11/include
conftest.c >/dev/null 2>conftest.out
configure:13634: checking for location of cairo library
configure:13654: checking for cairo linking flags
configure:13670: checking for cairo_create
configure:13696: gcc -o conftest -g -O2 conftest.c -L/usr/local/lib
-L/usr/X11/lib -lfreetype -lfontconfig -lXrender -lSM -lICE -lX11 -lcairo
   1>&5
configure:13730: checking for cairo_xlib_surface_create_with_xrender_format
configure:13756: gcc -o conftest -g -O2 conftest.c -L/usr/local/lib
   1>&5
configure:13789: checking for cairo_xlib_surface_get_xrender_format
configure:13815: gcc -o conftest -g -O2 conftest.c -L/usr/local/lib
   1>&5
configure:13857: checking whether to use FreeType
configure:13876: checking for location of FreeType includes
configure:13902: checking for ft2build.h
configure:13910: gcc -E conftest.c >/dev/null 2>conftest.out
In file included from configure:13906:
/usr/local/include/ft2build.h:56:38: error: freetype/config/ftheader.h: No
such file or directory
configure: failed program was:
#line 13905 "configure"
#include "confdefs.h"
#include <ft2build.h>
$ locate ftheader.h
/Developer/SDKs/MacOSX10.4u.sdk/usr/X11R6/include/freetype2/freetype/config/ftheader.h
/Developer/SDKs/MacOSX10.5.sdk/usr/X11/include/freetype2/freetype/config/ftheader.h
/usr/local/freetype/freetype-2.3.9/include/freetype/config/ftheader.h
/usr/local/include/freetype2/freetype/config/ftheader.h
Seth
It looks like you need --with-freetype-includes=/usr/local/include/freetype2
The configure script (intentionally) won't attempt to figure this out
for itself.
That seems to have fixed it and I'm now compiling. Thanks!
~Seth
hard
for itself.
