[GRASS-user] Compiling winGRASS with OSGEO4w- #2
About our prevous conversation here goes the compilation of Wingrass with OSGEO4w following a tip from Martin (not installing GRASS desktop from OSGEO4W)
1- I identified the extra modles that GRASS-desktop installation requires and installed only thse (except GRASS_locale and GRASS_gdal).
2- Run all thee steps from http://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstalling until COMPILING AND INSTALLING GRASS (GRASS6.4.0) step 1.
3- Downloaded a Weekly snapshot from here http://grass.osgeo.org/grass64/source/snapshot/ (http://grass.osgeo.org/grass64/source/snapshot/grass-6.4.svn_src_snapshot_2010_06_12.tar.gz)
4- Unpack gz and then tar to c:\osgeo4\usr\src
5- Inside C:\osgeo4w\usr\src\grass-6.4.svn_src_snapshot_2010_06_12 I runned:
./mswindows/osgeo4w/package.sh
(currently, no folder named grass is in c:/osgeo4w/apps)
  • in my first (3) attempts I got errors in libraries that I installed in step 6 of the Wiki. I had to Reinstalled them.
  • log includes my log file from this process (at: http://pastebin.com/UdhLyv6f)
  • error.log is the error report. I got errors in almost all executable.
QUESTION1:How can I add Python support to yes ? ( I will need Wxpython and use pythonscripts and probably pygdal)
It created:
a grass folder in /apps/
  • folder named bin in apps/grass with 2 files: grass64 and grass64.bat
  • a folder name grass-6.4.0svn with the following fodlerd: bin; bwidget; docs; driver, etc, fonts, include; lib; locale; scripts; tools.
and it seems to be running but all the functions in error.log are not available.
QUESTION2: What did I did that was wrong?
6- I went to C:\osgeo4w\usr\src\grass-6.4.svn_src_snapshot_2010_06_12\display and runned
make -C d.histogram MODULE_TOPDIR= C:\osgeo4w\usr\src\grass-6.4.svn_src_snapshot_2010_06_12
because d.histogram is one of the functions that is not available
And I got:
make: Entering directory /c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/display/d.histogram' make: *** No rule to make target /c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/lib/libgrass_display.dll’, needed by /c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/bin/d.histogram.exe'. Stop. make: Leaving directory /c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/display/d.histogram’
THank you
Luisa
(attachments)
error.log (4.6 KB)
After a few messages exchanged wirh Martin Landa (thanks Martin) I realized that the problem is only with libgrass_display.dll that cannot be found. Is the only problem. Has anyone ever had the same problem?
2010/6/14 Luisa Peña <luisapena1979@gmail.com>
It created:
And I got:
THank you
Luisa
OSGEO4W)
http://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstallinguntil
runned:
- in my first (3) attempts I got errors in libraries that I installed in
- log includes my log file from this process (at:
Says:
gcc -shared -o /c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/lib/libgrass_psdriver.6.4.0svn.dll ...
      0 [main] sh 432 open_stackdumpfile: Dumping stack trace to sh.exe.stackdump
The linker crashed trying to generate libgrass_psdriver. This will
cause build failures for libraster and libdisplay, then for all d.*
modules.
Unfortunately, I don't have any answer to this.
You'll need to figure this out yourself. The --with-python option
requires python-config, which isn't provided on Windows. It also
requires SWIG.
But even if you manage to get that to work, I've never managed to
successfully link against the wxWidgets libraries with MinGW.
However: note that --with-python isn't required for Python scripts,
and --with-wxwidgets isn't required for the GUI.
Back again with this issue. Thanks Helmut and Antonio for your help but so far I haven’t manage to compile GRASS using OSGEO4W. (and it seems that neither Antonio)Since Glynn told me that I might have some issues with newer versions I decided to use older versions of prebuilt and MinGW packages.
1- From oSGEO4W I installed the packages listed in step5 and 6
2- Runned msys and created osgeo4W folder and the fstab
3- Edited fstab
4- DOwnloaded the following packages (Since Antonio tried with newer and it didn’t work I decided to get the ones that are linked with Wiki):
5- Then I unpacked them to c:\osgeo4w
6- Downloaed Make from http://downloads.sourceforge.net/mingw/make-3.81-MSYS-1.0.11-2.tar.bz2
7- Unpacked it to c:\osgeo4w\apps\msys
8- Downloaded the following pre-built binaries:
9- Unpack it yo c:\osgeo4 I overwritted all files even if some file was newer… Is this ok? (iconv.h and m4.exe)
10- Reboot the PC
11- Extracted latest GRASS snapshot into C:\osgeo4w\usr\src
12- Using Msys I entered in GRASS source
13- run ./mswindows/osgeo4w/package.sh &>log.log (I suppose I don’t need to change anything right? not even in Platform.make or grass.mkae)
13.1- First attempt: It stopped at
checking for location of OpenGL includes…
checking for GL/gl.h… yes
checking for GL/glu.h… yes
checking for location of OpenGL library…
checking for OpenGL library… ./configure: line 11435: 3840 Segmentation fault (core dumped) ( eval $ac_link ) 2>&5
configure: error: *** Unable to locate OpenGL library.
13.2- Second attempt: Without changing anything it passed over the OpenGL and found library… (HOW can this happen? because I didn’t change anything…)
Tue Jun 15 17:08:27 GMTDT 2010: STARTING cleanup
Tue Jun 15 17:08:45 GMTDT 2010: END
Ok I had erros in:
/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.mapcalc
/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.mfilter
/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.mfilter.fp
/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/raster/r.thin
14.1- running make in r.mapcalc folder I get this error:
c:\osgeo4w\bin..\lib\gcc\mingw32\3.4.5........\mingw32\bin\ld.exe: cannot find -lgrass_rowio
collect2: ld returned 1 exit status
make: *** [/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/bin/r.mapcalc.exe] Error 1
14.2- running make in r.mfilter
make: *** No rule to make target /osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/lib/libgrass_rowio.dll', needed by /osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/bin/r.mfilter.exe’. Stop.
14.3- Running make in r.mfilter
14.4- running make in r.thin
make: *** No rule to make target /osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/lib/libgrass_rowio.dll', needed by /osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/bin/r.thin.exe’. Stop.
Ok So the problem now is: libgrass_rowio.dll. How can I debug this dll and How can I create it? And what might be happening?
This was a HUGE IMPROVE :slight_smile:
Thank you
Luisa
It created:
And I got:
THank you
Luisa
