[GRASS-user] compiling --with-glw on suse 10.1
hi,
in the moment i'm a little confused about the compiling-option --with-glw.
on my suse 10.1-laptop configuration with this option everything is ok.
on my new suse 10.1-pc there comes up an error-message in the configuration-step (sorry i'm not near the pc in the office for the exact error-messages).
little question:
what means exactly --with-glw? so maybe i can check then missing libraries (x11, ?....)
greetings and thanks in advance
helli
______________________________________________________________________________
"Ein Herz für Kinder" - Ihre Spende hilft! Aktion: www.deutschlandsegelt.de
Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen America's Cup-Yacht!
That switch is unnecessary for normal compilation. It's only required
for r3.showdspf, which isn't normally built; if you want it, you have
build it manually (e.g. "make -C raster3d/r3.showdspf").
As similar functionality is now provided by NVIZ, r3.showdspf is
deprecated.
little question:
The GLw library provides OpenGL "canvas" widgets for Athena and Motif.
r3.showdspf uses the Motif widget (so you also need a Motif library,
e.g. Lesstif or OpenMotif).
is --with-motiff used in any other place, except r3showdspf module?
Maris.
PS. I published this hint about GLw on GRASS wiki page.
http://grass.gdf-hannover.de/wiki/Compile_and_Install#Configure_options_and_they_meaning
2006/12/6, Glynn Clements <glynn@gclements.plus.com>:
Motif is also used by xganim.
