Hi All --
Does anybody here know of an existing GRASS modules that
will compute the major and minor axes for the polygons of
a vector map?
Thanks and best,
Ben
Hi All --
a vector map?
Thanks and best,
Ben
On 21/11/14 23:19, Benjamin Ducke wrote:
Hi All --
a vector map?
I don't know how you define these axes for a polygon, but I imagine that v.voronoi's '-s' flag might help you (grass7); at least for the major axis.
Moritz
IIRC is the code to compute the major and minor axes already in GRASS. You need to perform a Karhunen-Loewe-Transformation for each Polygon. This is also known as principal components analysis.
Best regards
Soeren
Am 21.11.2014 23:33 schrieb “Benjamin Ducke” <benducke@fastmail.fm>:
Hi All –
a vector map?Thanks and best,
Ben
grass-user mailing list
grass-user@lists.osgeo.org
Right, a PCA of the polygon vertices, I assume?
Maybe "v.to.db" could be enhanced to allow it to upload
the lengths of the first two/three components to the
attribute table?
For a quick fix, I solved the problem in a shell script using
a crude approximation. FWIW:
0. Set major axis length=-1
1. Rotate polygon by 10° (v.transform)
2. Fit region to polygon (g.region vect=).
3. Get width of region. If it is greater than major axis length,
set "major axis length = width"
4. Repeat from 1, until polygon has been rotated 350°
5. Minor axis length = height of current region.
Like I said, it's just a crude approximation (precision can
be increased by using smaller rotation steps) and slow, too.
But it's good enough for my purposes, which is basically to
calculate "elongation=len(major)/len(min)".
Best,
Ben
This is also known as principal components analysis.Best regards
SoerenAm 21.11.2014 23:33 schrieb "Benjamin Ducke" <benducke@fastmail.fm
<mailto:benducke@fastmail.fm>>:Hi All --
Ben
grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
Hi Ben,
2014-11-24 22:50 GMT+01:00 Benjamin Ducke <benducke@fastmail.fm>:
Exactly, create a covariance matrix from the vertices coordinates of
each polygon
and compute the eigenvectors and eigenvalues of these matrices.
Best regards
Soeren
attribute table?For a quick fix, I solved the problem in a shell script using
5. Minor axis length = height of current region.Like I said, it's just a crude approximation (precision can
calculate "elongation=len(major)/len(min)".Best,
Ben
Ben
http://lists.osgeo.org/mailman/listinfo/grass-user--
Dr. Benjamin Ducke
{*} GIS DeveloperSpatial technology for the masses, not the classes:
Wow, What a smart approach!
Nikos
