[GRASS-user] Concatenate raster values
Dear community,
is it possible to concatenate raster pixel values using r.mapcalc or/and
existing modules?
Something like the following examples
- expression = "product_20 = concatenate(20, input_map)": a value of 88
  in the "input_map" would mean the value 2088 (or 20088) in the output
  "product_20" map.
- expression = "product_25 = concatenate(25, input_map)": a value of 13
in the "input_map" would result in the value 2513 (or 25013) in the output
"product_25" map.
- expression = "product_nb = concatenate( product_20, product_25):
finally, the output pixel value, derived from the above examples, would be
"2008825013".
Thank you, Nikos
Le Tue, 30 May 2017 17:34:59 +0200,
Nikos Alexandris <nik@nikosalexandris.net> a écrit :
Dear community,
or/and existing modules?
Pixel values are numerical by definition, so I wouldn't think so.
88 in the "input_map" would mean the value 2088 (or 20088) in the
output "product_20" map.
Just find out what the highest value your input map and go to an order
of magnitude high enough to do this (i.e. if max(input_map)<100):
"expression = product20 = 2000 + input_map"
13 in the "input_map" would result in the value 2513 (or 25013) in
the output "product_25" map.
would be "2008825013".
product_nb = product_20 * 10000 + product_25
Moritz
* Moritz Lennert <mlennert@club.worldonline.be> [2017-05-30 18:00:59 +0200]:
Dear community,
It would be convenient, in some cases, I think. Think, somehow, of r.cross but
instead of assigning a new category value, a/the combination would be a
concatenation of the input (integers in this case, to make it simple)
raster values.
I've thought of that, as I have read it elsewhere. Yet, I rejected it
because I want to combine (maybe too) many maps together and still be
able to read fast the original values of the input maps. Maybe I should
study it more.
Perhaps I should name the `input_map` in the examples more precisely,
say: input_map_20, input_map_25, et.c.
This is experimental work. My actual goal is to retain all input values
from all input maps in as few as possible, or one if possible, map.
I was thinking of something like bit patterns, much like the QA bands of
Landsat products work, but it'd be perhaps more complicated to work
with.
I've found that I can play with the mapcalc's '@' operator, to get the
category labels assigned as raster values (when they are integers).
For example, the cat/label rules
0:
6:2006
13:20013
19:20019
would give a map with the labels in place of the cat values after
expression = "product_20 = @input_map_20"
If I repeat this for all of the different, yet similar, input maps, and,
then, combine again in the end the products... ?
Thank you Moritz, Nikos
