[GRASS-user] concatenating/combining two table fields for multi-field join
Hello,
would like to make a table join based on two fields.
So suppose I have to create a new temporary join field (joinkey).
I have the fields area (C2) and value (D2), per one area these do not
repeat.
So in Excel I did for preparing the source table for the other values:
=(C2 & D2)
How can I perform the corresponding command on the command for the GRASS
table?
Thank a lot in advance,
Timmie
table?
In
http://grass.osgeo.org/grass65/manuals/sql.html I found:
v.db.update vectormap column=column3 qcolumn="column1 || column2"
running the command on my data yields:
#dbmi: Protocol error
#dbmi: Invalid procedure 107
#ERROR: Fehler beim Ausführen von: 'UPDATE vectormap SET joinkey="a_value
What causes this error and what could I do to prevent it?
table?
In
Which database backed are you using (dbf, sqlite, postgresql) ? The manual does state that this command "does not work for DBF driver".
Moritz
