On 23/04/15 16:44, Ahmet Temiz wrote:
thank you Nikos
I meant that creating buffers from a line, which also querying DEM values.
DEM is in subquery position of buffer map
You cannot do that directly, AFAIK, but using r.mapcalc you can combine the two variables. Different paths are possible. Here's one (supposing a buffer of 500m):
- Create a raster map with distance to the line using r.grow.distance
- Use r.mapcalc in order to check for both distance and DEM value, e.g.
NewMap = if(DEM > 100 && DEM < 200 && distance < 500, 1, null())
This will give you a map with non-null (value 1) in those pixels that are within the buffer distance and that correspond to the DEM-related condition.
Is this what you are looking for ?
Another path would be combining r.buffer output with the DEM in r.mapcalc.
Moritz
regards
On Thu, Apr 23, 2015 at 1:28 PM, Nikos Alexandris
<nik@nikosalexandris.net <mailto:nik@nikosalexandris.net>> wrote:
* Ahmet Temiz <ahmettemiz88@gmail.com
<mailto:ahmettemiz88@gmail.com>> [2015-04-23 12:16:49 +0300]:
> hello,
> Which function can we use to generate a map that has conditional buffering
> according to DEM from a line ?
Hello Ahmet,
I don't understand the "from a line" part of your question. Yet, I guess
you mean to keep a specific range of DEM values.
You can directly use r.mapcalc for such tasks.
1) Remember to set the extent and the resolution of the active
computational region, it'll be also the one of the new map produced by
r.mapcalc
2) r.mapcalc 'NewMap = if( DEM > 100 && DEM < 200, DEM, null())'
This example will write only DEM values between '100 < DEM < 200' in the
"NewMap" and will set to NULL all other pixels that don't satisfy the
above expression. For more, please look at r.mapcalc's manual.
Of course, all this is valid and achievable via the GUI.
Regards, Nikos
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
grass-user mailing list
grass-user@lists.osgeo.org
