hi all, how I can configure spgrass6 to work with svn 6.5 Gis grass because I get the next instance in the console
library(spgrass6)
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.7.2, released 2010/04/23
Path to GDAL shared files: /usr/share/gdal17
Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
Path to PROJ.4 shared files: (autodetected)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: (GRASS not running)
some idea about, thanks for your help and time.
Ricardo Rodríguez
Univalle
marisn
2
How about fixing error You got? I'ts quite clear - GRASS not running.
Start GRASS and then from within GRASS start R.
Second option is to set all required GRASS env variables.
Maris.
2010/10/7, Ricardo Rodríguez <ricardorodot02@gmail.com>:
library(spgrass6)
GRASS GIS interface loaded with GRASS version: *(GRASS not running)*
Ricardo Rodríguez
Univalle
