[GRASS-user] configure: error: *** Could not determine External PROJ.4 version."
I am trying to install Grass 6.3 from sources on Mac OSX 10.5 and I get the following error:
"checking External PROJ.4 version... configure: error: *** Could not determine External PROJ.4 version."
In the config.log file, I see:
configure:6805: checking for location of External PROJ.4 includes
configure:6831: checking for proj_api.h
configure:6839: gcc -E -I/opt/proj/include conftest.c >/dev/null 2>conftest.out
configure:6873: checking External PROJ.4 version
configure:6893: gcc -o conftest.dSYM -g -O2 -I/opt/proj/include conftest.c 1>&5
configure: failed program was:
#line 6881 "configure"
#include "confdefs.h"
#include <stdio.h>
#include <proj_api.h>
int main(void) {
  FILE *fp = fopen("conftestdata","w");
  fprintf(fp, "%d", PJ_VERSION);
  return 0;
I have the Proj library installed in /opt/proj, and I've run the checks that come with the Proj installation package, and as far as I can tell it is installed correctly (it passes all of the included tests).
Does anybody have any suggestions on what to do?
thank you,
Laura
There are problems when configuring with the default CFLAGS (-g -O2 above). The debug flag causes trouble with configure in some cases. Set CFLAGS and CXXFLAGS explicitly before running configure, like:
export CFLAGS=-Os
export CXXFLAGS=-Os
(-Os is the standard OSX optimization)
If you really want debug symbols, then you must edit platform.make after configuring to add -g to CFLAGS and CXXFLAGS.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
As William says, set CFLAGS to something without -g when running
configure. Onc configure has finished, you can use e.g.
  make CFLAGS1='-g -O2'
to override the CFLAGS value passed to configure.
A detailed description of the issue can be found in:
http://lists.osgeo.org/pipermail/grass-dev/2008-May/037803.html
This has been fixed in the 6.4/7.0 development versions.
Oh, neat. Better than editing platform.make.
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
