Markus:
Who knows what the configure means by “TIFF missing?” But here’s the configure file and the result:
(base) [root@godelsrevenge grass-7.8.5]# ./configure \
–with-cxx \
–with-gdal=/usr/bin/gdal-config \
–with-proj --with-proj-share=/usr/share/proj \
–with-geos \
–with-sqlite \
–with-nls \
–with-wxwidgets=/usr/bin/wx-config \
–with-fftw \
–with-cairo --with-cairo-ldflags=-ldfontconfig \
–with-freetype --with-freetype-includes=/usr/include/freetype2 \
–enable-largefile \
–without-odbc \
–with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
–with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
–with-zstd
checking host system type… x86_64-pc-linux-gnu
checking for gcc… gcc
checking whether the C compiler (gcc ) works… yes
checking whether the C compiler (gcc ) is a cross-compiler… no
checking whether we are using GNU C… yes
checking whether gcc accepts -g… yes
checking for Cygwin environment… no
checking for mingw32 environment… no
checking for executable suffix… no
checking for full floating-point support… yes
checking for pwd… /usr/bin/pwd
checking for source directory… /grass-7.8.5
checking for build directory… /grass-7.8.5
checking for git… /usr/bin/git
fatal: not a git repository (or any of the parent directories): .git
checking for MacOSX App… no
checking for MacOSX architectures… no
checking for MacOSX SDK… no
checking how to build libraries… shared
checking for additional include dirs…
checking for additional library dirs…
checking for a BSD compatible install… /usr/bin/install -c
checking for flex… flex
checking for yywrap in -lfl… no
checking for bison… bison -y
checking for ranlib… ranlib
checking for ar… ar
checking for env… env
checking for perl… /usr/bin/perl
checking how to run the C preprocessor… gcc -E
checking for ANSI C header files… yes
checking for limits.h… yes
checking for termio.h… yes
checking for termios.h… yes
checking for unistd.h… yes
checking for values.h… yes
checking for f2c.h… no
checking for g2c.h… no
checking for sys/ioctl.h… yes
checking for sys/mtio.h… yes
checking for sys/resource.h… yes
checking for sys/time.h… yes
checking for sys/timeb.h… yes
checking for sys/types.h… yes
checking for sys/utsname.h… yes
checking for libintl.h… yes
checking for iconv.h… yes
checking for langinfo.h… yes
checking whether time.h and sys/time.h may both be included… yes
checking for off_t… yes
checking for uid_t in sys/types.h… yes
checking return type of signal handlers… void
checking for ftime… yes
checking for gethostname… yes
checking for gettimeofday… yes
checking for lseek… yes
checking for nice… yes
checking for time… yes
checking for uname… yes
checking for seteuid… yes
checking for setpriority… yes
checking for setreuid… yes
checking for setruid… no
checking for drand48… yes
checking for putenv… yes
checking for setenv… yes
checking for nanosleep… yes
checking whether setpgrp takes no argument… yes
checking for long long int… yes
checking for int64_t… yes
checking for W11… no
checking for X… libraries , headers
checking for dnet_ntoa in -ldnet… no
checking for dnet_ntoa in -ldnet_stub… no
checking for gethostbyname… yes
checking for connect… yes
checking for remove… yes
checking for shmat… yes
checking for IceConnectionNumber in -lICE… yes
checking for library containing cuserid… none required
checking for asprintf… yes
checking for atan… no
checking for atan in -lm… yes
checking for dlsym… no
checking for dlsym in -ldl… yes
checking for iconv… yes
checking for socket… yes
checking for location of zlib includes…
checking for zlib.h… yes
checking for location of zlib library…
checking for deflate in -lz… yes
checking whether to use bzlib… no
checking whether to use zstd… yes
checking for location of zstd includes…
checking for zstd.h… yes
checking for location of zstd library…
checking for ZSTD_compress in -lzstd… yes
checking for location of External PROJ includes…
checking for proj.h… yes
checking External PROJ major version… 6
checking External PROJ minor version… 3
checking External PROJ patch version… 2
found PROJ version 6.3.2
using new PROJ version 5+ API
checking for location of External PROJ library…
checking for proj_pj_info in -lproj… yes
checking for location of External PROJ data files… /usr/share/proj
checking whether to use regex… yes
checking for location of regex includes…
checking for regex.h… yes
checking for location of regex library…
checking for regcomp… yes
checking whether to use Readline… no
checking whether to use GDAL… yes
checking for gdal-config… /usr/bin/gdal-config
checking whether to use libLAS… no
checking whether to use PDAL… no
checking whether to use NetCDF… no
checking whether to use GEOS… yes
checking for geos-config… /usr/bin/geos-config
checking for geos_c.h… yes
checking for initGEOS in -lgeos_c… yes
checking whether to use TIFF… yes
checking for location of TIFF includes…
checking for tiffio.h… no
configure: error: *** Unable to locate TIFF includes.
I hope you can see something. I’ve now memorized the ./configure text!! I see the next-to-last line:
“checking for tiffio.h” and the response: “no” hmmm. I don’t know what that means. Maybe you can explain it.
