[GRASS-user] Configuring GRASS source code for compilation under Ubuntu 7.10 -- CFLAGS and LDFLAGS parameters no more necessary (?)
I just downloaded GRASS with:
$ sudo svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
I try to compile (under Ubuntu 7.10) as I did in the past with:
$ sudo CFLAGS="-g -Wall" LDFLAGS="-s" ./configure --with-cxx
--with-freetype=yes --with-ffmpeg=yes --with-postgres=no
--with-sqlite=yes --enable-largefile=yes
--with-tcltk-includes=/usr/include/tcl8.4
--with-freetype-includes=/usr/include/freetype2
--with-ffmpeg-includes=/usr/include/ffmpeg
--with-opengl-libs=/usr/include/GL --with-readline
but I get:
"sudo: CFLAGS=-g -Wall: command not found"
and an error as well for "LDFLAGS="-s" (in case I remove CFLAGS)
These "configure-parameters" are in the script makegrass.sh
http://david.p.finlayson.googlepages.com/makegrass.sh
found in
http://grass.gdf-hannover.de/wiki/Compile_and_Install#Ubuntu_6.06.2C_7.10
After removing these parameters the configuration worked fine (with the
exception of errors about missing documentation).
If these parameters do not work anymore should I update the script file?
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
but I get:
sudo takes the first argument as the command to execute. If you want to include several commands (CFLAGS= is one, LDFLAGS= another and configure the third), put them into a script file.
But why do you want to compile as sudo ? This is generally considered unsafe. You should only use sudo for 'make install'.
Or use the debian (and thus Ubuntu) way: dpkg-buildpackage.
Moritz
Yes correct.
I did recently a new clean install of almost everything on my machine.
The same with GRASS and I forgot to add the proper rights in
GRASS-source folder and files.
So I was getting an error and I thought trying with sudo will do the
work... which is of course wrong.
Thank you!
> but I get:
Moritz
Nikos Alexandris
but I get:
You would need to invoke the shell explicitly, e.g.
  sudo sh -c 'CFLAGS="-g -Wall" LDFLAGS="-s" ./configure ...'
To avoid dealing with quoting issues, you could store the command as a
script, then use e.g.:
  sudo sh script.sh
