Sorry for the n00bish question, but I'm confused by the GRASS on-line docs.
I have a MySQL database running on my local computer. Let's say that the MySQL user name is TRD and he has access to a database called TRD where I want to store my StateBoundaries table.
I can start the GRASS (6.4.0) Python interface and select "Database->Manage Databases->Connect" from the pulldown menu. I am then faced with the choice of driver, where I select "mysql". But, then it needs the Database name. This is where I get lost. The string in the text field says, "$GISDBASE/$LOCATION_NAME/$MAPSET/TRD". I'm not sure where GRASS is getting the values that substitute for those things that look like script variables. I guess the "$LOCATION_NAME" and "$MAPSET" come from the location and mapset that I selected when GRASS started. But, where is "$GISDBASE" set?
I also step through the log in process by setting the appropriate user name and password. I know that I can use this combination to access the MySQL database through its command line interface.
The next thing I do is try to test the connection. However, this results in lots of errors like, "Cannot connect to MySQL, Access denied for user" and "ERROR: Unable to open database <$GISDBASE/$LOCATION_NAME/$MAPSET/TRD>". It looks like GRASS is not using the right username and password and not doing the variable substitution that I was expecting.
Can anoyone give me some hints on how to get this thing started?
Thanks!
Thom
Man will occasionally stumble over the truth, but most of the time
he will pick himself up and continue. -- Winston Churchill
