[GRASS-user] Connecting Vectors to Attribute Tables
Dear All,
I am having some difficulty viewing an attribute table from a vector file that is connected to a sqlite database table.
Here is the terminal snippet of my commands with errors:
GRASS 6.4.0RC5 (SantaMonicaBayMM):~ > v.in.db driver=sqlite database=/USers/andrewlewin/MM_SMB.db table=MMSightings1 x=LONG y=LAT key=cat out=MMSightings_layer2Writing features...
  100%
Copying attributes...
DBMI-SQLite driver error:
Cannot scan date:"Date"
WARNING: Unable to fetch data from table <MMSightings1>
WARNING: Unable to copy table
Building topology for vector map <MMSightings_layer2>...
Registering primitives...
1897 primitives registered
1897 vertices registered
Building areas...
  100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
  100%
Number of nodes: 1803
Number of primitives: 1897
Number of points: 1897
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.in.db complete. 1897 points written to vector map.
GRASS 6.4.0RC5 (SantaMonicaBayMM):~ > v.info MMSightings_layer2
  | Layer: MMSightings_layer2 |
  | Mapset: PERMANENT |
  | Database: /Users/andrewlewin/grass |
  | Title: |
  | Map scale: 1:1 |
  | Map format: native |
  | Name of creator: andrewlewin |
  | Organization: |
  | Source date: Tue Mar 2 15:03:07 2010 |
  | Type of Map: vector (level: 2) |
  | Number of points: 1897 Number of areas: 0 |
  | Number of lines: 0 Number of islands: 0 |
  | Number of boundaries: 0 Number of faces: 0 |
  | Number of centroids: 0 Number of kernels: 0 |
  | Map is 3D: No |
  | Number of dblinks: 0 |
  | Projection: x,y |
  | N: 34:58:27.012N S: 0 |
  | E: 0 W: 119:18:54.72W |
  | Digitization threshold: 0 |
  | Comments: |
GRASS 6.4.0RC5 (SantaMonicaBayMM):~ > v.info -c MMSightings_layer2
ERROR: Database connection for map <MMSightings_layer2> is not defined in
        DB file
GRASS 6.4.0RC5 (SantaMonicaBayMM):~ > v.db.connect map=MMSightings_layer2 table=MMSightings driver=sqlite database=/Users/andrewlewin/MM_SMB.db
The table <MMSightings> is now part of vector map <MMSightings_layer2> and
may be deleted or overwritten by GRASS modules
Cannot create index:
create unique index MMSightings_cat on MMSightings ( cat )
table MMSightings has no column named cat
WARNING: Cannot create index
Select privileges were granted on the table
GRASS 6.4.0RC5 (SantaMonicaBayMM):~ > v.db.connect -p map=MMSightings_layer2
Vector map <MMSightings_layer2@PERMANENT> is connected by:
layer <1> table <MMSightings> in database </Users/andrewlewin/MM_SMB.db> through driver <sqlite> with key <cat>
There are errors from the point at which I try to make a point vector from the table. Any help would be appreciated.
Andrew
Andrew Lewin, M.Sc., Adv. Dipl. GIS
Email: andrew.lewin@sympatico.ca
Tel: (905) 639-4646
Mobile: (905) 630-8441
Skype: andrew.lewin99
Andrew Lewin wrote:
Dear All,
100%
Is there a column named "Date". Maybe because it's an sqlite reserved word, importing the table fails.
