Thanks for your prompt reply, Luca.
Unfortunately it doesn’t work: I started importing without the z flag and, as you can see, didn’t obtain any information about elevations.
GRASS 6.1.cvs (Valledaosta):/media/sda7/zodoardo/cartografia > d.what.vect -x ma p=noz0351
Building spatial index …
100%
Buttons
Left: what’s here
Right: quit
406529.90978316(E) 5051417.65316489(N)
noz0351 in zodoardo Line
length 2531.588789
Layer: 1
category: 15614
driver: dbf
database: //media/sda7/zodoardo/cartografia/grassdb/Valledaosta/zodoardo/dbf/
table: noz0351
key column: cat
cat : 15614
entity_nam : POLYLINE
color : 256
weight : -1
layer : 12L04
block :
txt :
Done.
On 7/20/06, Luca Casagrande <luca.casagrande@gmail.com > wrote:
I don’t know if the v.in.dwg works like v.in.ogr, but i think you don’t need the 3d flag…Try to remve it. In your example you need a 2d vector with z in the attribute table.
Bye
Luca
On 7/20/06, Odoardo Zecca <odoardo.zecca@gmail.com> wrote:
I need to extract some contour lines from a vector map (imported with v.in.dwg -z). While I can do this on the base of their category, it would be easier to directly select the desired elevations, but I don’t know how to refer to them. With d.what.vect I obtain the following textual output:
GRASS 6.1.cvs (Valledaosta):/media/sda7/zodoardo/cartografia > d.what.vect -x ma p=dwg0351
100%
Buttons
Left: what’s here
Right: quit
405718.49528848(E) 5051089.77547112(N)
dwg0351 in zodoardo Line
length 4098.283965
Line height: 560.000000
Layer: 1
category: 15833
driver: dbf
table: dwg0351
key column: cat
cat : 15833
color : 256
weight : -1
layer : 12L04
block :
txt :
Done.
The problem is that “Line height” doesn’t appear in the dbf table.
What can I do?
Thanks.
Odoardo
Odoardo Zecca
Institut Agricole Régional
Aosta (It)
grassuser mailing list
grassuser@grass.itc.it
