I'm relatively new to GRASS/unix style commands and was wondering if anyone
had a quick PERL script that could convert LOTS of raster maps to PNG files
without the repetition of going through one by one. I'm not much of a
programmer otherwise I'd write some kind of loop and have a go. The general
form of my rasters is already in a "Name_$Date" style format so I think this
should be pretty easy? I'm attempting to make video files that illustrate
soil saturation with time. I have about 10 years (daily) of soil moisture
that I'm looking to animate so it's a digestible amount of information.
I’m relatively new to GRASS/unix style commands and was wondering if anyone
without the repetition of going through one by one. I’m not much of a
programmer otherwise I’d write some kind of loop and have a go. The general
form of my rasters is already in a “Name_$Date” style format so I think this
should be pretty easy? I’m attempting to make video files that illustrate
that I’m looking to animate so it’s a digestible amount of information.
wondering if anyone
files without the repetition of going through one by one. I'm not much
of a programmer otherwise I'd write some kind of loop and have a go.
The general form of my rasters is already in a "Name_$Date" style
but none of those really strike me as beginner-friendly. (mea culpa)
the general idea is:
# set up region
g.region rast=
# use g.mlist to list all relevant maps
g.mlist rast pattern=
# eg throw those map names into a loop
my @maps = system(g.mlist rast pat=soils.*);
my @maps = `g.mlist rast pat=soils.*`;
for my $m (@maps) {
print $m;
`d.erase`;
`d.rast $m`;
`d.out.file $png_name`
probably it is good to first run through a loop of all the maps with
'r.info -r' and get the overall range, then create color rules covering
that entire range and in a loop apply it to all maps with r.colors.
that way the color scale stats the same.
Thanks for that write up. I just wanted to ask what the purpose of the /tmp/
line was. It seems like the conversion ran through just fine, but I don't
see any of the files saved to a specific place. Is the "/tmp/" listing the
folder directory where the files are written?
daniel mcinerney-2 wrote:
you could use the following bash for loop as a
basis for what you want to do:
for file in `g.mlist rast pattern=searchpattern*`;
do r.out.png input=$file output="/tmp/"$file".png";
done
Daniel
On Tue, Apr 12, 2011 at 5:10 AM, Mortsde <alex.mortsde@gmail.com>
wrote:
Hi Community,
anyone
files
general
this
Thanks for the advice but I'm still having some hangups with your code. Are
these commands meant for a unique script, entry into the terminal itself,
other...? The "my @maps" is confusing, what is the my representing? I
understand that @maps is referring to the map-file locations. The rest of
the code has me lost as well...
Thanks again!
wondering if anyone
# set up region
g.region rast=
for my $m (@maps) {
print $m;
`d.erase`;
`d.rast $m`;
